as above. XTR IS calipers no mounts at the moment 160 F+R
thanks
Posted : 17/03/2010 8:14 pm
IS to IS Doh!
Posted : 17/03/2010 8:24 pm
If you use a Rear caliper on the Front you don't need an adapter for 180mm, otherwise you need a +20mm adapter, but that could potentially add flex to the caliper mount causing noisy brakes.
Posted : 17/03/2010 9:13 pm
I heard that a +20mm won't work on 183mm rotors?
Posted : 17/03/2010 9:16 pm
Post mount or IS mount forks ?
Posted : 17/03/2010 9:48 pm
Hope don't do a IS to IS adaptor for 183 discs you would be better with a 180 disc and these adaptors http://www.chainreactioncycles.com/Models.aspx?ModelID=13736
Posted : 17/03/2010 10:02 pm
3mm diameter difference is only 1.5 mm radius, there should be enough play in the mounting holes to allow for that.
Posted : 17/03/2010 10:27 pm
