Going 1x9 on Commut...
[Closed] Going 1x9 on Commuter Bike
[#4872460]
Currently running 2x9 on my commuter but never use the small ring, thinking of going 1x9 - will I need a chain guide to prevent dropping the chain?
Bike is an old hardtail which has been urbanised. Set up is X9 shifters, X9 long cage mech, shimano 105 crankset.
If I need a chain guide I probably wouldn't bother. Anyone done similar successfully without requiring a guide?
Thanks
Posted : 15/02/2013 9:09 am
I run 1x9 on my commuter. I just use an old front mech tensioned from the cable stop on the seat tube. Works a treat.
Posted : 15/02/2013 9:15 am
1x9 here an no regrets
39t Surly SS ring
BBG light guard/bash
N-gear jump stop
11-28 cassette
Posted : 15/02/2013 9:27 am
I have a pretty much identical setup to reggie, works a treat 🙂
Posted : 15/02/2013 9:59 am
do it!
works brilliantly for me, go for a dh ring if you like as they are a bit thicker and unramped, i have a 44t version of this
http://www.chainreactioncycles.com/Models.aspx?ModelID=28192
youll want one of these
http://superstar.tibolts.co.uk/product_info.php?cPath=56&products_id=362
or one of these if going over 42t
http://superstar.tibolts.co.uk/product_info.php?cPath=56&products_id=475
Posted : 15/02/2013 10:05 am
I would say try it without a derailleur and see how it goes. In my experience it has to get pretty bumpy before the chain comes off.
Posted : 15/02/2013 10:08 am
What shermer75 says.
I'm running 1x10 with a Stylo crank and an SLX RD, and never dropped a chain, even on bumpy gravel. Using a singlespeed chainring might help a bit too.
Posted : 15/02/2013 11:42 am
And I dropped the chain once a ride at least, even with a ss chainring. No probs since the jump stop and bash
Posted : 15/02/2013 1:39 pm
I run 2x9 on my commuter, middle and outer on the front.
The middle ring's larger than usual and the cassette's fairly wide range (11-36?) so I can get up any hills on my route, and then cruise along the flat high in the range. The outer ring's just for fun in case I want to go down some decent hills or manage to find a tailwind.
Basically my commute's mostly flat but I have the option to go over some fairly steep hills, so if that sounds like your area, then maybe give it a go before you go throwing your front mech and shifter away.
Posted : 15/02/2013 2:34 pm
1x8 here. SS specific change ring with short cage rear mech and chain length adjusted accordingly. Never had an issue with chain coming off..
Posted : 15/02/2013 2:48 pm
