A while back it seemed to be TF Tuned. Are they still the go-to for self service kits? Rockshox is what im looking for
Ta
TF Tuned or J-Tech tuning are the 2 companies I use for Lyrik and Pike service parts.
Bike-discount used to be my go to, I found TF were way off on their prices. As long as you know the part number you need just order it from wheverever. If you want to go next level you can size the orings yourself and probably buy enough to do the life of the fork for the same price.
I had come on here to ask the exact same question!!
After a lower leg service kit for my Reba A7 forks. They have 4mm foam rings and every kit I can find is either 5mm or 10mm. Really struggling to find the kit I need.
Just looked at J Tech and they're kits don't say what's in them which is a little annoying.
100 hour kit for my RS SID is £55 from tf tuned. Out of stock nearly everywhere else so I've bought one for £40 off an eBay shop in Taiwan
Just looked at J Tech and they’re kits don’t say what’s in them which is a little annoying.
Just give them a ring they’re really helpful usually.
I've dropped them an email. Let's see what they say. I've bought the wrong kit before and just had to reuse the same foam rings before so they could do with being replaced really.
Qbikes on eBay are usually pretty good but their kits aren't right as they have 3.5mm foam rings, not 4mm. 🤔
And the German places aren't shipping to the UK it would seem.
Ruth and the guys at tftuned are brilliant
Give J Tech a ring. They had a part in that no-one else had and were recommended by the other suspension places when I needed it.
TfT are good too.
