Go pro positioning
[Closed] Go pro positioning
[#6480867]
I've got a Go pro 2 and positions for filming so far have been (1) handle bar mount result a little shaky but maybe the best result so far , (2) head mount, only used this once but it was very bouncy footage, maybe need a neck brace
Posted : 13/09/2014 5:10 pm
The bouncing on your head is probably the helmet wobbling around - your head stays pretty level when riding (even when the rest of you is moving).
I like the chest mount - it gives a bit of perspective with the rider's arms in shot, it stays pretty still and doesn't make your neck ache like the helmet mount can. Angle is critical though.
Posted : 13/09/2014 5:18 pm
Used ours on the bars and on the chest but not had a problem with it been shaky. Using the original gopro mounts but have bought a second chest mount from ebay very cheap from China and I cant tell the difference.
Posted : 13/09/2014 5:20 pm
Think you could right about helmet I will try again, chest mount is from China glad for your comment
Posted : 13/09/2014 5:26 pm
An old vid of mine with a few different mountings. I've got a video somewhere with some other views, I'll see if I can find it
Posted : 13/09/2014 5:34 pm
Chest mount
Mixture of mounts
Posted : 13/09/2014 5:41 pm
Found it - jump to 2:24 for an interesting viewpoint
Posted : 13/09/2014 5:51 pm
Thanks all it realy shows I need to do some experimenting
Posted : 13/09/2014 7:20 pm
Just to mix it up, pointing backwards from the seat post is a good view if people are following you.. and surprising stable on a full-suss!
Posted : 25/09/2014 5:51 pm
 Muke
I have one of these for mounting things on the end of your axle
Posted : 25/09/2014 6:36 pm
