Is it just me or is the pie run a nasty bit of trail.
Personaly i hate this bit of trail, its hard to keep and speed or flow, the roots are all managable apart from that bitch of a corner with the large root step down which i have fallen on, does anyone share my view?
I love Pie Run 😀
Fan of it myself - like the trees up close like that on the st, like the twists and turns.
Probably is hard to ride fast - good trail to sharpen the racing skills (if that's your thing).
Yeah, and who put all those trees in the way ??
I usually do the full red and miss out this short cut.
<counts down before someone complains that it's been sanitised>
Pie Run is an optional section so easily avoided if you don't like it- go up and do the red proper, or just roll down the fireroad to mushroom pie. But I do love it, it's something a bit different from the rest of the trails and breaks things up nicely. And IMO it has flow coming out the ears.
FWIW the bitch of a corner- called Trail Perfection- genuinely is one of the harder bits on the red. As proof, it's the only bit I couldn't do on my cross bike 😥 It's still definately in grade IMO, but it's a darker shade of red than the rest of glentress.
[i]I usually do the full read and miss out this short cut.
[/i]
But in the full red you should be coming back up the fireroad and doing the Pie Run.
I also hate the dodgy root corner, but like the Pie Run - good at night too.
[quote=b r ]
No. Coming up the fire road, the red route is clearly signposted off to the left. The Pie Run is a shortcut for those wishing to avoid the full red.
druidh - according to my (local) riding buddies, its only a full red (for a Strava time) if you climb back up and do the Pie Run
* yawn *
[b]Hit Squad Hill, The Matrix and The Pie Run[/b]
Classic Glentress downhill follows: the trail is steep, rocky and twisting through the big dipper style Hit Squad Hill. At the bottom, follow the forest road, climbing past the viewpoint on your right and up towards The Matrix, with its mogul-style features. After Lombard Street, a steady forest road descent will bring you to the top of the Magic Mushroom.[b]To climb or not to climb?[/b]
If you want to cut out The Matrix and in particular the climb up to it, you can opt for the Pie Run.
http://7stanesmountainbiking.com/Glentress---Innerleithen/The-Glentress-Red-Route
Jeez, NEVER argue with druidh.
NOOb
Pff, signs. Everyone knows the One True Red has a lap of Zoom or Bust, a quick dick around on the jumps, and the Bitch instead of Lombard St, and then back up and do Pie Run. And possibly after Sair Fecht you go up to the Buzzard's and come down the blue, just because it's fab. PS Spooky woods optional.
Aye, there's always a dick around on the jumps Northwind.
Sometimes it's me, sometimes it's some other dick.
Although this doesn't make much sense, I'm guessing that you need to practise. I love this bit of trail. Maybe it's because I worked on it, including wheelbarrowing tons of hardcore for it. Seems a lot longer bit of trail when you are pushing a heavy wheelbarrow along it. Luckily we had child labour we took full advantage of.
[quote=stevenmenmuir ]we had child labour we took full advantage of.
You might want to re-word that
Love the pie run. Not so keen that the drop has got bigger at the end so had to go back to looking before leaping
Blimey, I was going to post saying the drop at the end had got easier!!
Another vote for the pie run, great little bit of trail. I just wish that there was more of it. It is a shame that the corners have been squared off on Zoom or Bust as that used to be better.
Always link back up to it after the "full" red run myself too....
This said root tree rooted drop at the end of the pie run ... ive only been to gt once an also chickened out of said drop .... what's people's opinions on how it is ridden ? From a outside view to me it looked like there was a line on the far right hand side kinda going long ways around the drop ?
jono84 - MemberThis said root tree rooted drop at the end of the pie run ... ive only been to gt once an also chickened out of said drop .... what's people's opinions on how it is ridden ? From a outside view to me it looked like there was a line on the far right hand side kinda going long ways around the drop ?
Which bit exactly do you mean? Seems a bit like you might mean the black option onto the fireroad, since that can be taken as a drop?
As the piece of trail now becomes know as the "pedo run", in honor of steven menmuir's faux pas....
With the trail being so tight and narrow I can see why children may have been used. 😆
Mark N - Memberbeing so tight and narrow I can see why children may have been used.
This thread continues to horrify.
Possibly it was a fair few months ago since I did it but the section as I remember was really rooty leading up to it an there was a right hand corner which doubles back(switchback?) an seems to drop off /roll off half way round the corner/switch back about a foot
Am i being dense or do you have to pay for a GT trail map now???
Yah, I know it- there's a wee bit of boardwalk just after? Used to give me a lot of bother, that one, so I get where you're coming from- the wee step wouldn't bother you normally but you're turning at the same time. It's actually easier than it seems and no great science to it- Just stick the front wheel down it and then follow it, pretty much.
It's changed a little recently- the root collapsed on the right hand line which in some ways makes it easier- the step's lower- but now the higher part on teh left puts some people off I think.
Just to clarify we only used them to shift barrowloads of hardcore. I have no idea what they got up to once they were back on the bus. One of the reasons there isn't more stuff like that is because it was so labour intensive. A lot of man hours went into what is a relatively short section of trail. I'm not even sure a repeat of that would be possible now that the fairies only meet once a month. If I remember right we even did a few evening sessions on it including a floodlit session although I think that was to repair the fast left hander before the first rooty section.
love it - sketchy bunnyhop line is a joy to clear
Thats the section northwind cheers I suppose like a lot of things in biking it's mind over matter
Double post
You used to be able to roll that drop at the end, but due to a bit of erosion its become a bum twitching drop. 😆
I'm so pleased that I'm not the only one who hates that little rooty stepdown turn. Rest of the red run is pretty easy, but I have never managed to get round that corner without falling on my ass. IMO Its the hardest bit of trail in all of GT, and I include the black in that.
Although I didn't ride it I wouldn't say I hate it I enjoyed the rest of the rooty section an it's nice to know in my head "next time I go I'm gonna ride that" or at least have a go if there was no challenge to it for me I'd lose interest I recon ... being in a trail center I also know everything is ridable so no excuses for me !
Neil F - MemberYou used to be able to roll that drop at the end, but due to a bit of erosion its become a bum twitching drop.
The black line onto the fireroad? Still rolls.
Whats not to like? its a trail centre, all easy riding then one section of trail making you work the bike, so work it 🙂
If your doing the full red then just ride up the road 1/4 mile before Magic Mushroom 🙂 hardly a hassel to do 😉
Heres a film how its done from a couple of years ago, jump all the tree roots, it is faster and easier, mate in front was an ex Scottish champ and makes it look easy, no way could keep with him 😉
Smash it up - class.
Defo one of the more interesting trails IMO.
A faster descent, though a bit over exposed, proves too hardtails are quick through the Pie run, though it is a mecca god rider in front who will not be on here for a wee while...
How long did he get this time?
It's the best bit of trail at glentress.
I prefer to think as the main red alternative an option for those wishing to avoid anything challenging 😉
Love the Pie Run and Mushroom Pie, big thanks to the trail fairies that built them 🙂
I always try to put the front wheel onto the stone part of that step. It is quite far to the right though which makes the turn sharper once the front wheel is down.
I have always liked this section and Hit Squad Hill.
Northwind - Member
I believe it was 10 years! 😯
TJ got big ban too
by the way, is it definatly an 'official' red trail as i dont know if you noticed but the trailmarker isnt a red arrow, its kind of an orange shape? i ride the matrix and lombard street sometimes but i enjoy mushroom pie more tbh. no i ride, spooky, super g, hit squad hill, roll down the fireroad, mushroom pie, magic mushroom.
