Giant trance shock ...
[Closed] Giant trance shock air woes
 kilo
[#5046029]
Got a 2011 giant trance x4, was adjusting the rear shock today as the bike had been unused for about 6 months, it takes air ok and holds it as long as the pump is screwed in but as soon as you unscrew the pump it dumps all the air out the valve - is it a sticky valve and is it repairable - it's a giant own brand shock. ta in advance
Posted : 08/04/2013 8:03 pm
Check if the valve pin has come unscrewed. You can get a tool to tighten it up
[url= http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_564255_langId_-1_categoryId_255241 ]valve tool[/url]
You could check if it's loose with tweezers or pliers. If it is, i'd recommend using the valve tool to tighten up properly.
Posted : 08/04/2013 8:41 pm
Sounds like the valve core is loose. It's a schraeder valve so you can get a core remover/fitter
Posted : 08/04/2013 8:45 pm
