I'm thinking of purchasing a shimano cx50 chainset from crc to go on my giant TCX.
However, it's got a press fit bb86 bottom bracket, which I know bugger all about! Is it as simple as knocking the old knackered one out, and fitting one of these:
http://clee-cycles.co.uk/esite/P1047/product
And fitting the shimano chainset?
James
shimano do a bb86/bb92 press fit BB that fit these frames/crank and LBS should be able to hook you up & fit
and use a proper tool to fit it wonky bearings are dead bearings.
[url= http://www.competitivecyclist.com/product-components/2013-shimano--bb86-bottom-bracket-6758.19.1.html ]Info on BB86[/url]
[url= http://www.parktool.com/blog/repair-help/bb90-bb86-bb92-etc-bottom-bracket-service ]Park tool BB86[/url]
It would appear from that, any standard Shimano hollow tech chainset wth integrated axle will dop straight in to a BB86 bottom bracket shell.
So different to BB30 which requires a BB 30 specific chainset.
Edit: sorry read our op again. Looks like the KCNC will work as would:
