Giant maestro beari...
[Closed] Giant maestro bearing press
 rock
[#2540366]
Hello,
I've failed miserably at trying to swap out the bearings on my anthem x2 using sockets and a hammer. Does anyone have one of those fancy dan maestro bearing presses that they would be willing to rent to me?
Cheers,
Dave
Posted : 07/03/2011 10:23 pm
 StuE
Where are you ?
Posted : 07/03/2011 10:25 pm
 Olly
an old quick release, and various sockets.
a hammer is no use, you have no control
the QR lets you ease a lot of pressure on, in a controlled manner, like a "real" bearing press.
MUCH power, little effort.
Posted : 07/03/2011 10:28 pm
That's ingenious!
Posted : 07/03/2011 10:40 pm
 rock
StuE - London
That press looks very cool. Is it literally just a series of sockets on a qr? Does the QR apply enough pressure?
Posted : 07/03/2011 10:41 pm
That will not work on a giant, they have odd shaped housing, rock I have a meastro puller and press, maybe we could work something out!
Posted : 07/03/2011 10:42 pm
 StuE
I have the Maestro bearing tool kit, but am in Leeds
http://www.giant-bicycles.com/en-gb/partsaccessories/product/maestro.bearing.tool.kit/1385/36212/
Posted : 07/03/2011 10:53 pm
 rock
StuE - i'm guessing it's too heavy to post?
Kaesae- are you based around london? I think it was you who I bought the replacement bearings from
Posted : 07/03/2011 10:56 pm
I got these from CRC, but have used 8mm threaded bar nuts and washers.
Posted : 07/03/2011 10:59 pm
 rock
lipseal - how do they work? DO you just use them with an allen key or spanner, or do you need a separate tool?
Posted : 07/03/2011 11:03 pm
 Olly
Thats a giant trance Kaesae.
Shhush.
the QR provides MORE than enough pressure.
choose a BIG socket thats teh appropriate size to support the outer edge, and choose a smaller one that fits through the back of the rocker, and pushes on the back of the bearing.
then take up slack in the QR by stacking sockets and other convenient implements.
do up the QR nut so that you can only move the lever a cm or so, if you try and pull it down all the way from the top it wont work.
little pushes with maximum leverage
to fit the new bearings without borking them, use an OLD bearing as a pressing surface, being a bit careful not to press it in so that it fits itself in on top of the new one permenantly.
here I have used an old, snapped, axel from a deore hub, and used the cone, pushing on the inside of the old axel, with a 21mm socket (zocchi top cap size) supporting the frame.
for some more "tool abuse"
this is a 24mm socket at the bottom, and an old spanner at the top, fitting a headset a bit less glamorously than i would have hoped
but it worked.
Posted : 07/03/2011 11:18 pm
Hope you get the idea.
Posted : 07/03/2011 11:19 pm
 rock
anyone know a decent lbs in london who could do this?
Posted : 08/03/2011 6:22 pm
@ Olly the frame has more bearings than just two, can you show us a photo of the upper rear triangles housing and how it works there?
Posted : 13/03/2011 7:51 pm
I would love to see that too...without the official tool.
Posted : 10/04/2011 2:33 am
