Ghetto tubless pres...
[Closed] Ghetto tubless pressure survey
[#926003]
What sort of pressures do you run in your conversions? I recently got a track pump (instead of just using the hand pump) and pumped up my [b]tubed [/b] tyres - thought "35 seems about right" - put 35 in and it felt WAY too hard so I dropped it to ~28-30ish. The last time I paid this much attention to tyre pressure was when I last fitted tubeless and I went for a value similar to my normal preference (probably 30ish by the feel of it) and I had the tyre roll off the rim in a corner.
I know it's all personal taste, I'm just curious as to the average sorts or pressures people use (and their body weight, I'm ~100kg).
Posted : 06/10/2009 10:12 am
Just under 30psi front & just over 30psi rear (hardtail), don't really know why the difference, just habit I suppose. Also run ghetto tubeless on the front and proper UST on the rear due to 'burping' issues on the rear. I'm ~90kg
Posted : 06/10/2009 10:19 am
28 in each for some reason just always have
Posted : 06/10/2009 10:24 am
I found 35 in my tubed tyres to be just about right, with a slight risk of pinch flats.
In my tubeless tyres i'm running 28, although they're probably slightly less than that.
I'm 11 stone-ish and have never had any issues with burping, I thought i cornered quite hard (for a 4" saddle-up hardtail anyway) but don't often land jumps sideways, so perhaps thats why.
Posted : 06/10/2009 10:35 am
25 front, 30 rear
2.35s on 719s
Posted : 06/10/2009 10:37 am
Seems like about 30ish should be about right then. I'll give it another go and see if I have burpy problems again.
I'm on fairly narrow x317 rims and 2.1's, they seem to pinch very easily with tubes.
High 20's to low 30's depending on conditions- normally about 28.
IMO integrated pressure gauges aren't accurate enough at these pressures- I always use a dedicated pressure gauge. A couple of psi can make a lot of difference to how the tyre works at these sort of pressures.
Posted : 06/10/2009 10:38 am
vinnyeh- I've never found a gauge that I could trust as "correct". I've seen differences of 2psi between dedicated digital ones on the same car tyre at the same time, I've seen +2 psi from a compressor gauge and -4 frmo a garage one. Bit of a minefield really!
Posted : 06/10/2009 10:40 am
I use the same gauge every time so it doesn't really have to be accurate - just consistent
Posted : 06/10/2009 10:42 am
That was my plan now, having finally got a track pump 🙂
Posted : 06/10/2009 10:53 am
With Nevs, 30/35 (according to the track pump) seemed to be the best feel between skitty and squirmy. I've done Advantages recently and suspect they can go a little lower as they have more rubber in them.
Posted : 06/10/2009 11:43 am
UST - 25psi
Normal ran tubeless - 28-30psi.
More flexible sidewalls on regular tyres require greater pressure to stop them being to squirmy. They all differ a little. I managed to run Tioga Fat 66 DH tyres at 18psi. That really was a magic carpet ride.
Posted : 06/10/2009 12:17 pm
