Ghetto Tubless and ...
[Closed] Ghetto Tubless and Latex
 spev
[#1137612]
So i'm trapped in the house with shingles ( I don't recommend it to anyone its bloody painful) and contemplating going ghetto tubeless (among other things). I've found some suppliers of liquid latex on the net like [url= http://www.homecrafts.co.uk/products-Liquid-Latex_M310.htm ]here[/url] anybody used similar products or should I stick with the proper stuff?
ta in advance (and any advice on the shingles would be great as well 🙂 )
Posted : 17/12/2009 8:29 am
It'll work OK but you need to mix it with some water, Slime & anti-freeze if you want it anything like commercial mixes
You can replace the Slime with other things - glitter, hair etc.
Posted : 17/12/2009 8:34 am
 spev
Ah sounds good, wonder what quantities to mix it at, will get the "intelligent" brother on the case (when he's not messing about in Porton Down)
Posted : 17/12/2009 8:36 am
Have a look here for ideas
http://forums.mtbr.com/showthread.php?t=320782
Posted : 17/12/2009 8:40 am
Have you googled it? I found a few sites that had various mixes, and you can tailor them to suit your requirements, like long life or giant hole filling.. (but I am yet to take the plunge myself)
Posted : 17/12/2009 8:42 am
 spev
not googled yet, been awake for 4 hours and my eyes arent working yet 🙂 6 hours sleep in the last 4 days is taking its toll. Going to add it all up and see if its worth it. I take it the slime it to provide the hole filling bit?
Posted : 17/12/2009 8:47 am
re shingles:
If your pain is genuinely severe, talk to your doc. Post-herpetic neuralgia can be prolonged and v painful. Predictors for it are increased age (I'm guessing you don't really fit there, we're talking old) severity of pain during the shingles and whether or not you had pain/sensitivity prior to the shingles appearing.
Early "aggressive" treatment might prevent or reduce the onoing nerve pain. Simple painkillers can & should be on the go already. (course, you may be on "aggressive" treatment right now)
Posted : 17/12/2009 10:12 am
 spev
cheers scaredypants, I was to late for the viral suppressing drug (by about 24 hours) i'm on painkillers but the rash on my side is right on the bit where I sleep and when I sit down its in the folds (I'm not fat) the burning is the worst bit as its constant. Really though its the cabin fever thats the worst
Posted : 17/12/2009 10:25 am
[url= http://forums.mtbr.com/showthread.php?p=4376252&page=4&highlight=home+made+sealant ]Extensive thread here[/url]. I have been thinking about doing this so would be interested to know what products you end up using and how it works out.
Posted : 17/12/2009 11:00 am
 spev
I've had a look at that one, I'm intrigued as to whether I can not use Slime, looking at the little bottle of JRA wheelmilk that I have it appears to be a thin solution of latex and something else(probably an antifreeze type thing and an anti coagulant to slow down the latex), i'm going to try latex, anti freeze and a shaved inner tube(for the hole blockers instead of glitter)
wont be doing it for a couple of days until I feel better though
Posted : 17/12/2009 11:09 am
there are other drugs that can be used for the pain (not coinventional painkillers) - you could still be eligible for these if necessary
Posted : 17/12/2009 11:15 am
I mix latex with water so it has the consistency of single cream and then add about 1/5 of the mixture as windscreen anti freeze stuff and then enough glitter that it looks pretty (big size glitter - your choice of colour) it works very well and doesn't dry out for around 3 months at least - been running for 2 years with no issues.
Posted : 17/12/2009 11:31 am
 spev
Scaredypants- if its not better by monday I'm off to the docs again, i'm taking co-codamol 30/500mg (I use them for my migraines) and they help with the pain.cheers though, i'll ask when im there about other options.
christoginger- i'll give that a go, do you use a standard track pump to inflate at the start or a higher pressure device?
Posted : 17/12/2009 11:39 am
This thread is bizzare
the intertwining of shingles relief advice is comical
Posted : 17/12/2009 11:42 am
I stumped up and got a 25 litre compressor as it takes away all the hassle,, inflate to 60psi shoogle the wheel about for a bit and thats you (2 years no punctures). I did get a tyre to inflate once off the track pump, but spent most of my time trying to find a car garage with an old style compressor!
However, extremely soapy water is the Key!!! get a brush and foam it up round the rim... 🙂
Posted : 17/12/2009 1:52 pm
