Ghetto tubeless wit...
[Closed] Ghetto tubeless with kenda nevegal
 ajc
[#443186]
Has anyone tried ghetto tubeless with a nevegal? They have quite thin side walls so am not sure if they are up to the job.
Posted : 02/04/2009 10:43 am
Yep. The thin carcass was causing intolerable numbers of punctures which is why I went ghetto tubeless:
JRA wheel milk 50ml per wheel
Schwalbe presta 24" tubes x2 (cores removable)
WTB lazerdisc rims
Nevegal 2.1" tyres
Lots of watery soapsuds (not soapy water)
Do an initial inflation with just the suds slopped on and the valve core removed. Squash the tyre down a lot because you are trying to get the bead to seat against the rim. I managed initial inflation with a track pump and some patience but a compressor would be better. Once up at 50psi and seated, leave it to slowly leak and go flat. Remove pump and inject JRA into the valve, then insert the core and inflate to 40psi. The sidewalls and bead will be leaky and more suds will show where. Keep sloshing, rolling and re-inflating over a couple of session until they seal - probably about an hour of this in total for both wheels. Mine don't deflate at all now.
Posted : 02/04/2009 11:06 am
er, I wonder why going tubeless isn't more popular 😐
Posted : 02/04/2009 11:16 am
I found they work ok as above but are a pain in the hole to get seated on 717s
Posted : 02/04/2009 11:34 am
I was driven to tubeless because of a spate of punctures when I got the bike which came fitted with Nevegals.
A couple of hours setup in the garage is less hassle than fixing punctures in the rain out on the trail, while you mates are waiting for you. 😀
Posted : 02/04/2009 1:33 pm
