I could do with some info here...
Will it work on any setup and what would I require to convert over?
Ta
Si
thought you were getting stans rims
Si
All the info you need is at Allan Kelly's site [url= http://www.tubelesswheels.com/howto.html ]here[/url]
JustRidingAlong has good info on tyre suitability and they sell the wheel milk.
Allan's site is very good. My only other tip would be to lie the wheel flat over a bucket when inflating - couldn't get mine to go up otherwise!
When you follow that website, if it isn't working, more suds are needed.
Not sure going 'ghetto' will save you from yesterdays mishap though...
Information needed ?
I've been using DT Swiss kits for a while and thought I'd give the 'ghetto' a go.
Are the Schwalbe tubes Al recommends 16" or 20" for a 26" rim?
Do [url= http://www.chainreactioncycles.com/Models.aspx?PartnerID=79&ModelID=24639 ]these ones from Chain Reaction[/url] have removable presta cores?
20" inner tubes, and yes, any Schwalbe ones should have removable valve cores.
Thanks Rev Will.
Is that 'should' or 'would', before I place an order. 🙂
They will have. I work in customer services, so I tend to be overly careful with statements.
Great. Thank you.
