Hi, guys, as the title suggests - anyone ever made or have any ideas of how to fashion your very own foam wiper for some ancient Psylo's (c.2001)?
Type of foam and a method of cutting to shape is what I'm after here. I know there are a few bright sparks around these parts so let's hear your suggestions, if you please...
Aren't Psylo's 30mm Stantions? Same as Reba/Tora etc?
If so, a dust seal kit is about £16 & if they're that age, possibly due a service.
Or a bag of 20 foam wiper rings can be bought from Fishers by your LBS for not a lot, so should be available for about £1 each.
I had the foresight to grab a couple of Revive Kits when I first purchased the forks so they've been regularly serviced since then. It's just that I'm down to my last kit so was looking at alternatives. I thought the other forks had gone up to 32mm but I'll go have a quick Google...
You're correct - Dukes are 30mm.
Ta
Reba/Tora now 32mm.
Sorry, my mistake - you didn't mention Dukes.
Got a link to the Fishers pack of wipers or are you suggesting they're only available through my LBS...?
I had a look on thier B2B site & they're listed as in stock & available in packs of 20 for 30mm stantions. (Really should know newer ones are 32mm, I only serviced three pairs last week 🙄 )
So any LBS should be able to get them, if you can't find them online somewhere-I haven't looked, but CRC/Merlin et al. might have them.
Thanks
Top bollock, Woody. Thanks very much...
Or:[url= http://www.rosebikes.co.uk/article/rock-shox-service-kit-245482/aid:245484 ]Wipers and foam rings from Rose linky[/url]
