Regardless of the science, which I should be able to work out but cant be bothered, I decided it was worth a try - try it before knocking it and all that. I ran it in some DH 2.25 mud tyres, and it made a very noticable difference to rolling resistance over normal XC tubes. It allowed me to run lower pressures, but I then found I dinged rims more regularly and when I had the tyre at low enough pressure to noticably improve grip the sidewalls flexed too much and the tyres would roll off the rim and "burp" during hard cornering. After the third case of being unable to pump it up on the track due to burps, having a side-wall tear that never sealed and having to clean out the dried and now useless latex in only 3 months of riding I decided to return to tubes. I now get punctures on virtually every ride. Frustrated. So I'm going to give it another try but using new better tyres and higher pressures, see how I get on. I have a litre of latex left 😀
In my (limited) experience if you have got to the point of ripping a tyre, if would be just as knackered with a tube in it, as you end up with the black bubble of doom then an almighty bang.Actually in that case you are better off again with tubeless, as you just get sprayed with white shit, whereas the tube can further tear the sidewall making a bodge impossible and leaving you with no other option but to walk.
So, you accept that you can get flats in the same way as a pinch flat. I don't see how the tube can tear the sidewall, that's nonsence.
"So, you accept that you can get flats in the same way as a pinch flats"
Not really no. Without a tube you cant get a snakebite and the tyre wont bloww off from a straight impact unless the beads are uber slack - in which case it won't seal in the first place :?. If your pressures are silly low e.g. <20psi, and the sidewalls are too weak, it might burp or roll under side pressure. This is not the same. Mine has burped in a crash when inflated to 25psi , but it re-inflated with a mini pump.
yes, cynic-al, ghetto is not fool proof. but...
with tubes, you can often get pinch flats that leave the tyre undamaged - these would be avoided tubeless
the lower pressures you can run might lead to more of these if you were running tubes, but the tyre is *much* tougher than the tube, so often not a problem
i do carry tubes, and tyre boots, in case of emergency, but get very few punctures of any kind compared to the three or four per ride i was getting that caused me to try it.
i've 'gone ghetto' on my xc bike, and my Dh bike.
and being a geek, i weighed stuff.
A 'normal' xc tube weighs 200g, a ghetto'd bmx tube weighs about 100g, you then add about 100g of sealant. So little weight benefit.
A thick Dh inner tube weighs 400g, so going ghetto saves 200g per wheel over Dh tubes.
every wheel i've done has needed a compressor, and lot's of patience, and a change of clothes after being sprayed in latex trying to get the bl00dy tyre to seat/catch.
whilst riding, it does seem a bit more puncture proof - even quite nasty slate slashes have been sealed.
But, i've found i've had to run quite high pressures to stop the tyre 'burping' over rocks - i've never heard a 'Burp', but have had latex sprayed over my legs. and finished descents with a lot less air in my tyres than when i started.
I've had tyres that have just given up, and deflated over night, after seeming to be fine for weeks.
and other gripes too numerous to mention here.
Verdict (based on my experience)
pointless for xc; - no weight saving, unreliable, and a faff to re-ghetto when it goes wrong. i haven't had any punctures, but have had plenty of 'deflations' - way more than i'd expect through good old fashioned thorns and pinches.
it is a valid weight saver for Dh wheels tho' - the bigger tyres / rims seem to give more reliable results. still a faff to sort out/change tyres on race day (high rollers to mud spikes for example).
it's got me thinking tho' maybe we NEED to fiddle around with unreliable bits of bike kit. Back in the day we had brakes that didn't work at the best of times, frames that broke, wheels that folded, tyres that didn't grip, gears that jumped, etc, etc. bikes were cr6p, but we still loved them, maybe that's WHY we loved them.
Modern bikes are basically sorted, there's no real reason why you can't ride hard for years without suffering a single mechanical/component failure.
Maybe we've just invented Ghetto/tubeless because it give us something to fiddle around with/bodge/fettle/swear at. maybe we need to feel that nagging doubt of 'i did my best, but i'm still not sure if it'll work'.
or maybe i just like getting covered in a spray of sticky white latex goo.
while I wouldnt sell it as a good point about tubeless, he does have a point - when you have a normal tyre and get a tear, the tube tends to push it outwards and split the carcass further before going pop or catching the frame/rocks and going pop. With tubeless the rip remains very small, which means you can apply a patch internally and throw in a normal tube to get home. Irecently had exactly this situation with a normal tube/tyre combo, I actually watched the tear in the tyre "unzip" as I got off to see what the wobble was.
conversely I ghetto tubeless's the front wheel on my single speed and the tyre was dead (worn down completely), and I had to cut the fricking tube off as it was completely glued to the tyre and tore when I was trying to separate the two.
As for the tearing, well I've seen it on two of my tyres in the past, a NN and a Conti something, the NN the sidewall tear got opened up to around 1 1/2", and the Conti, it split the bead and made about a 6" tear and as CK you can watch it doing it.
I nearly deafened myself and nearly lost some fingers last night
I was trying the Ghetto my first rim, an OneOne 29er Reetard with a Schwalbe Little Albert (Folder).
All going well, went straight up first time on the track pump, great.
as per the instructions over pumped it to about 60 PSI and BANG!
Nearly deaf, Dead Fingers for an hour or so and Latex sprayed everywhere
DOH!
The tyre looks fine no splits, so it just seems to have slipped off the rim
Anybody else had this?
Have any of you done on with folders? Or do all stick to non folding tyres which I assume have a stronger bead.
Tyres do go on the Reetards extremely easily as opposed to a set of DT's that I have which I can't get a tyre on without levers so it's probably a rim thing too I 'spose
Did you use epoxy instead of latex by mistake, rich?
last poster, forgot who you are, I have only ever run ghetto with folding tyres.
Stans fluid and washing up liquid only, it had been in there around 8 months tho.
Curious, will watch out for that. My only worry was whether the latex (or more specifically the ammonia content) would damage the nice new tyres Ive got.
I though ahwiles experience was very interesting. I agree there is no weight saving. But I've stuck with ghetto tubeless for XC on the FS because it went together easy enough and it's been so trouble-free!
My HT has tubes, but it has Maxxis aDvantage tyres which don't seem nearly so puncture prone so I haven't felt the urge to ghetto them.
It really must depend of rim/tyre combos.
I think a lot of the problems people are having are down to experience and practice, which, granted, is a pain on a potentially messy/annoying job.
Every time I do one now, i take more time preparing the wheel/tyres and work area, and every time its goes up easier and is more reliable.
The most important thing i've found is to build up the rim bed with rim tape/insulating tape. The more you build it up the more tricky it is to get the tyre on, but once done it is far more likely to inflate easily, and I [i]think[/i] should be less prone to burping as there is less slack in the tyre to begin with.
Ahwiles, if you could ever be convinced to try it again, I reckon that was the problem. On your other point about complications on bikes, I agree! Problem is, having tried a working tubeless system, i couldn't go back...
Oh yeah I've had maxxis ones separate from carcass as well, but they were well used.
Ghetto = cheapskate bastards. Why would you spend over £2k on a bike and then go for the cheap option on one of the main areas? Beggars belief
Furry muff lads - I've never seen that, must be weak sidewalls.
Why would you spend £50 on the "real deal" when you could spend £10 and do exactly the same job, just as well? That would just be stupidity.
And not everyone has £2ks worth of bike.
Fell for that one.
She's a looker alright.
Edit: Booooooooooooooooo! Rubbish edit 😡
You prefer the fish?! Fixshed 😉
Racing Ralph - thats a ridiculous thing to say! Have you actually tried a ghetto conversion? So you're saying a 'real' kit is better just because it comes in a neat little package and costs £50??!!! You beggar belief 🙄
I must be very lucky as i had no probs at all, so far.
I knew weight savings would be minimal as simple maths proved. I did so purely to stop thorn punctures, something i get alot of on my local trails around bristol. Tyres do feel like they have abit more grip though.
You beggar belief
Nope, you do - I fell for it so everyone else didn't have to, but you still did 😆
WTF
nickegg - MemberRacing Ralph - thats a ridiculous thing to say! Have you actually tried a ghetto conversion? So you're saying a 'real' kit is better just because it comes in a neat little package and costs £50??!!! You beggar belief [:roll:]
NOOB
I had relatively few problems getting everything to work first time around. Changing tyres was a nightmare - had to start all over again, and now have problems losing pressure over a few days. Gone back to tubes, but will try again sometime cos the ride is better on tubeless imho.
I posted on Sunday " Just went Ghetto" . Been on three rides since. Bike is definatly faster. Very similar to taking off nobbly mud tyres and putting on faster summer tyres. Also the bike seems to ' pop ' more easily , and slightly more stable. Bear in mind I used to run slimed tubes to keep punctures at bay. The poster who weighed everything did not allow for 100ml of slime, plus the tube,when with Ghetto you can use less latex. Slime in tubes seems to bunch up and you can feel it when you spin up the wheels and sometimes in the corners.
So far with my Gheeto'd wheels I have not noticed this effect anywhere near as much.
Initially I ran them at 35 psi , but it was obviously too firm. Dropped them to 30 psi and its closer, maybe another 2 -3 psi less will be spot on for me.
No problems fitting them . I got them up on the bead , deflated then carefully injected the wheel milk.
Got to thinking maybe a turkey baster might be the right tool for the job.
STM
I run ghetto tubless
Is it faster? I dunno. Very subjective.
Is it grippier? Dunno. Again subjective.
Is it lighter? Probably not by much, if at all.
Do I get fewer punctures? Yes yes yes yes yes yes yes.
Not one (other than a dodgy tyre which i tried to use, which was my fault) since converting.
Previously I was pinch puncturing about twice per ride on thick-ish tubes & high pressures. This was mainly from riding fast rocky stuff.
I'd recommend it to anyone pinch puncturing a lot.
Well excuse me for not understanding another english saying!
I shall assume that is what i have missed.
Nick on forums people take the piss and wait for reactions - fishing!
I see. I obviously have not been using this forum long enough. Usually i would be at work but redundancy means i have too time on my hands!
Can't wait to get another job!
