Getting cleat bolts...
[Closed] Getting cleat bolts out
[#1667268]
Managed to get two of the blighters out but still a bolt stuck in each and rounded off a bit. My plan, unless anyone has a better one, is to saw off old cleat until I can get mole grips on bolt and twist it out. Sound like a plan? What are cleats made out of? Always assumed they were some softish brass alloy?
Posted : 02/06/2010 8:00 pm
Either bang a slightly bigger torq bit in there and buzz it out with an electric drill, or drill the head off and use pliers/stillys to ge tthe left over out
Posted : 02/06/2010 8:09 pm
reach for the drill
Posted : 02/06/2010 8:10 pm
Ooh had this fun last week. Time bolts are made from diamond took ages to get the git out. Tje drill is your friend
Posted : 02/06/2010 8:12 pm
Drill 'em out or jump in the time machine with a tub of copaslip.
Posted : 02/06/2010 8:21 pm
Not a help now, but when you put new ones in fill the head of bolt with silicone. Then next time you need to take them out you have a lovely clean hole for you allen key.
Posted : 02/06/2010 8:22 pm
Slightly crazy suggestion here, soak stuck bolt wih WD40 (or better still PlusGas) then try TIGHTENING the bolt a tad to break the rust lock and then attack with the oil again, let it soak and hopefully undo.
Try using a nice new alan key too.
Posted : 02/06/2010 8:27 pm
Drilling them out is the only way.
Posted : 02/06/2010 8:34 pm
shimano bolts are very soft - easy to round out but equally easy to drill out
Posted : 02/06/2010 8:44 pm
Got the first two out with the plus gas.
Will get busy with the drill tomorrow night.
cheers all
Posted : 02/06/2010 8:48 pm
