Genesis vapour vs R...
[Closed] Genesis vapour vs Ridgeback flight
[#3953943]
as above,
i have 4 weeks until i can order using C2W scheme, i am a big lad (23 stone) and already have a full sus and a rigid mountain bike.
going to use new bike for commuting 2 miles to work and longer jaunts on my days off, mixture of road and sustrans type paths.
bike has to be from www.cyclesolutions.co.uk and im not really interested in a pure road bike.
my 2 main contenders are:
http://cyclesolutions-shop.co.uk/p48080/Genesis-Vapour-10-2012.aspx
or:
http://cyclesolutions-shop.co.uk/p48092/Ridgeback-Flight-03-2012.aspx
also, possibly slightly less likely:
http://cyclesolutions-shop.co.uk/p48606/Charge-Filter-Hi-2012.aspx
i need a bike that can manage a bit of everything (apart from proper off road stuff) and it has to be from cycle solutions.
anyone own any of these? your opinions please.
marty.
Posted : 08/05/2012 11:53 am
I had a Flite 03 for commuting in that London, 30 miles a day for nearly a year and it was great.
Go for that I would
Posted : 08/05/2012 11:58 am
i have until 4th june to decide, and i wouldnt be disappointed with any of these bikes.
Posted : 08/05/2012 12:12 pm
I've got the vapour - I'm big, but not as big as you and I find it fine.
Surely the biggest issue is going to be drops versus flat bars. I get on fine on the drops, but it took a while to get used to and the stock Vapour offerings were a bit on the narrow side (40 cm IIRC).
So you many want to budget for some larger bars if you go with the vapour.
Posted : 08/05/2012 12:22 pm
you are absolutely correct, its flats vs drops really.
im mostly thinking the vapour is the most useful to me, i plan to do LEJOG before i turn 50, and on longer rides drops give a bit more variety in position.
how much tyre clearance does your vapour have? thinking about mudgaurds too.
Posted : 08/05/2012 12:47 pm
Tyre pressure from memory is about 60psi
I've not put guards on it, but it shouldn't be a problem depending on tyre width.
I do like mine - I have a spesh sirrus (similar to the Flight) with flat bars, but I tend to ride the Vapour more.
If you are anywhere near Perth, and you are looking at a 56, then you would be welcome to come and try it.
Posted : 08/05/2012 2:20 pm
