Sorry, I know these threads are a bit silly, but I thought it was worth asking.
I can get an iO for a good price but the catch is it'll have to be a 16". I'm about 5'8.5" - is this out of the question? I'm pretty sure I ought to be on the 17.5".
Cheers,
MM
Totally depends on lots of things to be fair.
There is only 15mm in the top tube length between a 16" and a 17.5" though, so it's not worlds apart. I'm a couple of inches taller than you, and ride a 17.5" Altitude, but could probably get away with a 19" if I had wanted. I preferred to have a slightly smaller more nimble bike though.
If there's any way you can try it out for size before hand, then I suggest you do so.
I'm going to try it, but I'm not very experienced with mtbs (much more road experience) so my judgment from a short test ride may not be all that informative, hence my question.
5'7" and ride a 16" iO ... you'll need a pretty long seatpost but otherwise you should be fine.
5'11" on a 17.5" here. I would of thought you'd be ok.
Thanks for the replies, I guess I will have to see. Btw, if it helps, my road bikes range from a 53.5cm TT (which is the smallest I could ride) to a 55cm TT which is almost the biggest.
It's not like I even need a rigid SS, but it's so tempting... 🙄
im 6 foot and have a 17.5 so I would go with the 16" and 400mm seat post if I was you much nicer to have the smaller size if you can, lovely frames those btw
5'11" on a 17.5 here
Thanks for the replies, I should be trying the bike tomorrow.
I am 5'8" and i ride a small io. I find it v comfortable.
if you want a frame only in 16in - I have an IO frame I'm selling 🙂
I have the option of a complete, new bike with upgraded brakes for £350, so no thanks. 🙂
