I have an Trek X01 with road gearing from the previous owner.
I want to get a better gearing for hills and offroad and have at my disposal a 22/32 deore chainset, a 11-34 cassette and derailleur; the brifters are Tiagra 10 speed; will it work?
Probably 😉
I’d just think that 32/11 is quite limiting. I’m running 44/30 12/32 and that gets me up most things.
You'll need a 9 spd mtb mech, not a 10spd one. A road front mech might struggle with 22/32 but a mtb mech can be tricky to get working nicely with road shifters.
Chhers aP
Will the brifters pull enough cable is my initial thought.
Whats the average ring on 1x 9/10/11 that people use, it would be on 33 mm cross tyres; not those huge things that are the vogue.
way to many gears on the granny end.
22/34 - 0.64
32/11 - 2.9
I've got 11-40 50/34 on my bike.
34/40 - 0.85
50/11 - 4.5
Just to give you an idea of what easy gravel gearing would be around.
you'll need a mtb BB which is wider than the road version so the front mech might struggle to shift out enough and the Q factor will be wider. if the shifters are 4700 versions they won't play nicely with an mtb mech, other tiagra versions will work with 9sp mtb mechs though
you’ll need a mtb BB which is wider than the road version
If there actual any difference in the road and the mtb version? just curious, cause I was trying to diagnose a creak a while back and it's just the middle bit plastic internal muck cover that's different, was interchangeable.
Just wondered if there was any other differences? Never noticed when I had them out togther.
Road bb cups are 1mm wider than mtb ones iirc
Ref the 1x question-
40t ring with 11/32-36 depending on course for dry.
36t ring with 11/30 for mud.
42t ring for road with 11/32.
All fine.
simondbarnes
Subscriber
Just wondered if there was any other differences? Never noticed when I had them out togther.Road bb cups are 1mm wider than mtb ones iirc
cool, cheers.
cool, cheers.
But they run without spacers on a 68mm bb shell. You'll need to add spacers to run a mtb chainset as the axle is longer.
