Gearing changes - C...
[Closed] Gearing changes - CX bike 34t to 30t chainring?
[#11501002]
My ageing Boardman CX bike currently has a 50/34 front and lets assume 12/32 rear.
On steep off road climbs I struggle, it feels like I could do with another 2 gears at the rear. On the road, probably another 1 gear would be useful. However changing the front chain ring will be cheaper.
So will a 32 give me what I need, or do I need a 30?
Thanks
Posted : 27/11/2020 2:29 pm
https://www.sheldonbrown.com/gear-calc.html
Looks to me a change to a 30T chainring with existing 12-32 will only give you one easier gear than the current 34T.
Posted : 27/11/2020 2:50 pm
What BCD is your chainset? 34t is probably the smallest that you can fit if it's an older Boardman with 5 arm 110.
Posted : 27/11/2020 2:53 pm
My first thought also, does a 30t even fit on the cranks you have?
Posted : 27/11/2020 3:22 pm
Hmm it is 5 arm, can you not get 30t?
Big cassette on the back then !?!
Posted : 27/11/2020 4:13 pm
 Bez
Yeah, that’s a 110 so 34 is as low as you go in the front without new cranks.
Posted : 27/11/2020 4:18 pm
50/30 is also likely to be more than your front mech can handle, so you'd need a smaller big ring. You're either looking at a subcompact crank (46/30) or a bigger cassette.
Posted : 27/11/2020 4:21 pm
https://www.probikekit.co.uk/bicycle-cranksets-and-chainrings/shimano-grx-rx600-double-11-speed-chainset/12649530.html is 30/46, but then you will need to get Hollowtech BB, 11-speed shifters, mechs and cassette.
Posted : 27/11/2020 4:23 pm
Thanks I was hoping a new chainring would be the cheap option, new cassette it is and hope the rear mech can cope !
Posted : 27/11/2020 4:25 pm
Is that a 2014? I ran a 40t (sunrace) on the back with the stock apex wifli mech and a 40th single upfront for the 3 peaks last year and it was fine. Not sure what the effect would be using a double however. The 2014 teamcx is a bit of a lump (i'm using mine as a commuter at the moment with 40mm Marathons, mudguards, single 38t up front and it's not what you'd call sprightly, even on the road. It's pretty dependable though. I swapped the cranks out for some old 105's but the FSA's will be fine. You could probably get by with a 38t (cheapy from aliexpress about 7 or 8 quid) on a 5 arm crank and a 40t casette on the back.
The biggest issue I ever had was the BB, now has a Wheels MFG bb30 to ht2. About 80 quid but worth it over the stock press fit.
Posted : 27/11/2020 4:59 pm
The 2014 teamcx is a bit of a lump (i’m using mine as a commuter at the moment with 40mm Marathons, mudguards, single 38t up front and it’s not what you’d call sprightly, even on the road. It’s pretty dependable though
I think its the 2014 - grey with bits of yellow. I did 3 peaks on it 5 yrs ago and deeply regret not changing the gearing on it for that ok fitness wasnt great, but i dont think the bike particularly helped !
Posted : 27/11/2020 5:07 pm
Now it’s just a winter bike, it’s ok once rolling but the Landcruisers (once tyre of choice for 3 peaks) are hard work
Posted : 27/11/2020 5:29 pm
