gear shifter with n...
[Closed] gear shifter with non-terminated cable??
 5lab
[#2283780]
Got a remote seatpost (rase) but I don't like the handlebar release, so I was thinking of swapping it for something else. I run a 1x9 setup, so my thought was to use a left-hand (front mech) shifter. Trouble is, the end of the cable that goes into the handlebar release is unterminated - that is to say it is just a cable, which is clamped in place with a grub screw. I can't get to the other end of the cable, but I believe it is termanated (ie the cable is just a standard gear or brake cable, but the 'wrong way round') - as a result I can't just lop in a new cable the other way round.
So - what are my options? do any shifters have an option of using a non-terminated cable? or is there a way of adding a 'termination' to a normal cable (getting length right might be an issue after doing this)
H
Posted : 14/12/2010 4:13 pm
Just clamp a nut and bolt on to the end of it.
Posted : 14/12/2010 4:14 pm
Would the inner brass connector from a small (3 amp) terminal block be suitable. Have used these as makeshift repairs in the past.
http://www.screwfix.com/prods/98805/Electrical-Supplies/Cable-Accessories/Connectors-Blocks/CED-3A-Terminal-Blocks-Pk10#
Posted : 14/12/2010 4:38 pm
crimp and glue a piece of split brass on the end like a nipple?
Posted : 14/12/2010 4:40 pm
IIRC you used to be able to buy some sorts of nipple you could put onthe cable - not that small though.
Posted : 14/12/2010 4:42 pm
Try putting a big blob of solder on it - it can them be filed to shape afterwards.
Posted : 14/12/2010 4:51 pm
Would a cable swage work? Generally they're used for putting a loop in a cable, but an appropriate sized one could be trimmed to fit maybe?
Or something like this?
(can't link to the picture but...)
[url= http://www.tecni-cable.co.uk/3mm-A2-AISI-304-Stainless-Steel-Single-Shank-Ball-Terminal-100-206-644 ]http://www.tecni-cable.co.uk/3mm-A2-AISI-304-Stainless-Steel-Single-Shank-Ball-Terminal-100-206-644[/url]
edit: Or this one fits a 1.0mm to 1.5mm cable...
[url= http://www.tecni-cable.co.uk/Support?id=984 ]http://www.tecni-cable.co.uk/Support?id=984[/url]
Posted : 14/12/2010 5:02 pm
