Gear ratio help
[Closed] Gear ratio help
[#6051392]
Hey, so im thinking about swtiching up my 2x10 drivetrain to go 1x10 by adding a narrow wide chainring and a 40t cassette ring.
Currently i have 24-38 up front and 11-34 up back. i will need to get a new xt cassette so will go 11-36 on that.
Im unsure what size chain ring to get up front.... on my current setup i do use the granny ring to get up some hills but like wise like cranking down the fire roads in a higher gear..... what sort of gearing would a 36 chainring up front give? with an 11-40t cassette? or even a 34 seems the common choice for riders... will that still give a good granny gear when on the 40t cassette ring?
Thanks in advance for your help!
Posted : 20/03/2014 1:12 pm
dropping from 11-36/ 24-39 here and guessed at 34/36 for the front with the 40t rear, still going to involve manning up a bit and loosing a chunk of top end. There are some good calcs out there
for example
Posted : 20/03/2014 1:15 pm
Your ratio at f24 - r34 is 0.71
With a f30 - r40 you ratio is 0.75
If you want to match ratio you need a 30.
With a 36 that rises to 0.9.
Final drive for f30 - r11 Is 2.73.
A f36 - r11 is 3.27.
My partner is running f30 and r36 (getting 40t at the weekend) and doesn't run out of gears down bpw.
Posted : 20/03/2014 1:27 pm
ECheck your email mate!
Posted : 01/04/2014 12:33 pm
Hey sorry for slow reply, hectic month! thahsnk for your info. I was gonna go 34 up front but, im currently running a slx double chainset up front which is 64/104 bcd... I wanted to get a bashring aswell and mount the chain ring on the inner and bashring on the outer but limited to a absolute black 30t chainring as thats all i can find with 64bcd. Still not sure what to do hmmmm!
Posted : 14/05/2014 5:33 pm
