Sorry if this has been asked before...I refuse to £4.50 per m from LBS !
Cheapest? Best?
For SRAM X9/shifters.
Thanks to STW massive!
I stick with [url= http://www.parker-international.co.uk/5084/Shimano-SP41-Outer-Casing-4-mm-x-10-m.html ]this SP41 (XTR) pregreased [/url] from Parkers, grab your cable stops ferrules & end crimp caps off eBay.
To be fair I imagine buying 10m's of cable is a bit overkill for most ppl, but I've blasted through one lot easy enough, so longer term it's worthwhile
Used to buy XTR, now I just get Jagwire kits. Not something to scrimp on even if you can't see it.
My lbs, does jagwire for £1.70 per meter
Would I notice a difference over Clark's cables that I look after (blow through clean, really lube cable and outer) on my fully routed bike?
Surely the grease gunks up?
I bought a Shimano outer, a new cable and a crimp for £5 from my LBS for my rear mech. Maybe find a different LBS?
Where can I get an off road jagwire kit? Or do you use the road version?
Never had the grease junk up, as on a full cable run (mech to changer) there little chance for dirt enter the system. Can't say it definitely better than any other cable system, but I like this setup
[url= http://cgi.ebay.co.uk/Jagwire-Cable-Housing-Ripcord-Design-150-cm-colors-/400199102558?pt=UK_sportsleisure_cycling_bikeparts_SR&hash=item5d2db9b05e ]Jagwire.[/url]
I only ever use these!
