Gear/brake cable re...
Gear/brake cable recommendations?
[#12832179]
I need to replace the cables on my road bikes. I pine for the old days where CRC/wiggle et al had a look about a zillion full-kit options with teflon-coated innerw and pre-greased outers for about 5p.
Now it seems to be £30 for the most basic of crap.
Anyone got some recommendations?
Cheers!
Posted : 24/05/2023 8:27 pm
Shimano SP41 gear outer, Shimano BC9000 brake outer
Ashima Action + gear & brake inners.
Posted : 24/05/2023 8:50 pm
Gear outer -Shimano SP41 off the roll from your LBS, fitted with sealed SP4 end caps, 1.1mm stainless slick inners from any of the usual suspects (i'd recommend Elvedes, personally). Edit - Ashima Action + as per Simon above are very good too.
I buy a shimano kit if I need endy bits and ferrules and such, but then I reuse them til they break so inbetween I just get whatever stainless inner is cheap, and I got a roll of sp41 which'll probably last my whole life
Posted : 24/05/2023 8:54 pm
