Gates Carbon Belt D...
[Closed] Gates Carbon Belt Drive - Frequency?
[#7040728]
What frequency should the Gates carbon drive resonate at if it's at the correct tension?
They have a little tuner app but it doesn't work on any of the phones I have, but I do have a guitar tuner......
Posted : 05/05/2015 7:05 am
For internal gear hubs 45-50 Hz should be the target....this was when I was looking at a nexus hub on a build.
Posted : 05/05/2015 7:51 am
Hmmm
Mine is a single speed so maybe could go a little tighter.
Posted : 07/05/2015 8:42 am
Dunno. Mine is comparable to a chain-tension. If you run it as tight as suggested, you increase bearing wear (IME)
Posted : 07/05/2015 8:51 am
Its meant to be a lot tighter than a chain, which shouldn't have any tension (from what I've been told)
Posted : 07/05/2015 8:54 am
