Garmin/GPS help
[Closed] Garmin/GPS help
[#6170149]
Trying to sort out a big group ride in Italy.
I can send out GPS files of the route but I also want to send out a pile of way points. Is there an easy way to do this from Garmin Basecamp.
I can put them all on my 800 but how do I send them to someone else? Ideally as one file rather than 30 individual markers.
I want to put in meeting points, hotels, shops etc.
Anyone able to help.
Posted : 06/05/2014 10:07 pm
Assuming that you have all the waypoints and the route already in Basecamp then just put them all into a single 'List' in your library (the tree structure on the left hand side in Basecamp). Then click on your list in the library so it is selected. Then from the menus select File/Export and your list name should be already there. That should be it all into one file.
I'm not sure how your friends can import it without first reading it back into their own copy of basecamp though. The file is a gpx so they may be able to just drop it into their GPS's
Posted : 06/05/2014 10:20 pm
Upload to?
http://www.gpsies.com/#10_51.30486238965093_-0.300750732421875_mapQuest
Posted : 06/05/2014 10:29 pm
I can certainly get them all in one file which is good. You might be able to just drag them to the "new files" folder. Will try tomorrow but if not then people can go through base camp.
Posted : 06/05/2014 10:42 pm
