Which do people prefer? The one that sticks out front or the one that mounts directly above the bars? I prefer the look of the out front one but are they sturdy enough? Any recommendations?
Cheers!
I've used an on the bars mount and a combined edge and virb mount that sticks out in front of the bars. I'm not that keen on the way the shot sways around with a bar mount and think the sensation is worse with the camera further out front. The problem may be that I swerve all over the place like a drunken motorist.
Well I'll be using it for mountain biking if that's any help. Anyone else?
I use the standard tube mount on the bars, with a 100mm stem. Works fine. I imagine the out front mount will sweep too fast while steering and possibly be more prone to vibration.
I use a superstar gopro multi mount with the virb mounted under the bars.
http://www.superstarcomponents.com/en/gopro-multi-mount.htm
CNC machined for £15
I've got both types and haven't noticed much difference in picture quality, the Garmin out front mount is much neater with the Virb X/XE.
My biggest gripe is the amount of noise (gear changes etc) transferred from the bike to the camera.
Scholar that cnc'd one looks sweet! Any complaints? Do you happen to have a pic? Cheers.
I use the standard Garmin handlebar mount for VIRB from Wiggle, but I mount it upside down so it is below the handle bars. In the settings you can flip the camera so it later plays correctly on your PC. I rode a very bumpy track at Rivington and the image was unbelievably clear. Even clear on a cobbles ride. It is also seems very well held in the mount. If it does not come off on Rivi even after a low speed tumble, it should stay on anywhere.
