I forgot to switch off my GPS and its recorded my drive back home as part of my cycle ride. IS there a way to split the track in Garmin Training Centre??
Guilty of not answering the question....
I wouldn't bother. User Bikeroutetoaster or Memory Map if you have it. They are much simpler (and I knwo you can do what you wish to).
I've got Memory map, but it gets very slow if i import all the tracks that are currently in training centre. might try sport tracks.
can't you just import the route you want to split?
yes but for the live of me i can't remeber the site, ill try and dig it out.
Just navigate to the History folder on the 705, select the file and "Open With" Memory-Map, as if by magic, Memory-Map appears as does the track, you can then split the Track and save it where you want.
Dibbs, presumably you mean open the GPX file with MM? Has MM been updatd to handle TCX files yet?
