Garmin Edge 810 not...
[Closed] Garmin Edge 810 not charging?
[#7718736]
Ride this morning, powered it up and then it died about 5 seconds after power up. Wouldn't switch back on so just thought I'd left it on so killed the battery.
Rode without it, got home, plugged it in - powered up and showed 100% - little odd!
Done a hard reset and now showing 73% (which is about what I was expecting as 78% after last ride). Plugged it into mains and its now not budging off 73%.
Tried USB plug, computer and 2 cables, no change!!
Any ideas? Circuit? Battery? Firmware?
Short of taking it apart I'm out of ideas!!
Posted : 20/03/2016 2:39 pm
Does the computer recognise it when plugged in? If not then it could be water getting into the USB port.
Posted : 20/03/2016 2:46 pm
Yep tried that - registers its charging and registers as a device, lets me write and delete stuff from it no issues!
I've left it charging and its actually now started to creep up - maybe i'm impatient, maybe a glitch - probably needs a a while to see if I can replicate the fault again!
Posted : 20/03/2016 4:14 pm
