Garmin Edge 500 - u...
[Closed] Garmin Edge 500 - update 3.0 - be wary
[#4341067]
After updating to the new spangly software my edge is totally frakked.
I see on t'web there are many complaints about this update, especially if you are using a Mac.
I will have to send the bl##dy thing back to Garmin to be reset.
Posted : 07/09/2012 6:09 pm
mine has gone a bit t1ts up as well.
It works, but I can't auto download, I can only manual download.
I'm assuming thye will have a fix out soon.
can you reset the firmware back to 2.8?
Posted : 07/09/2012 7:25 pm
Yes, just updated mine and also playing up.
On Wednesday it didn't find any satellites for my entire ride. Thursday I left it turned on outside my house for 45 minutes before it managed to lock itself into position. Today it took about 15 minutes; still unacceptable!
Not good - also looking for a way to revert to v2.8
Posted : 07/09/2012 7:58 pm
Just to add a bit of balance I've had 3.0 on mine for ages and its been fine.
Posted : 07/09/2012 8:10 pm
Found this:
[i]"BUT BEFORE YOU INSTALL THIS UPGRADE, remove all the *.fit files from your Edge (you can store them on the computer) including the activities folder AND the courses folder (which I forgot about).
Some people upgrading with *.fit files left in the memory are experiencing issues ranging from inability to upload, to completely bricking the unit. "[/i]
Posted : 07/09/2012 8:14 pm
I put mine on 3.0 back in June and it's been faultless
It was a brand new unit though so maybe try Kryton's method if you're having issues
Posted : 08/09/2012 7:27 am
As someone who hasn't done any updates on theirs,and being a numpty on this sort of thing, how do you move files to the pc first? Thanks.
Posted : 08/09/2012 9:27 am
Just plug it into your PC and you'll see it as a drive
In the root there's a folder called Garmin, under this you have Activities and Courses
the .fit files are in those folders, copy and paste them to a backup folder somewhere on your PC
Posted : 08/09/2012 11:52 am
i have the same problem.
updates to 3.0 and now i cant measure distance and it wont record any data...
spoke to garmin and they told me all they could do was send it back and they could sell me a new replacement unit at a discounted rate.
Posted : 08/09/2012 3:11 pm
I checked my Garmin and I'd already upgraded to 3.00. However, I did a while ago have an issue, and the advice from Garmin was to remove all the fit files, perform a hard reset, replace the .fit files and all will be OK.
And it is, I just can't remember if that was before or after the upgrade.
Posted : 08/09/2012 3:47 pm
how do you do a hard reset?
Posted : 08/09/2012 3:55 pm
ta
Posted : 08/09/2012 7:36 pm
