Garmin Edge 200 Que...
[Closed] Garmin Edge 200 Question.
[#5386553]
Had my first ride out on the road bike with the 200 last night, all ok, but how on earth do I change it over to bike 2 (for my mtb)?
I've looked at the history & odometer 1 & 2, and they both show last nights ride details???
Posted : 02/08/2013 10:15 am
Do you really need too?
If you want separate data for different bikes, just use something like Strava and you can have as many bikes as you want.
Posted : 02/08/2013 12:34 pm
I've just read through the manual and I can't see that facility.
On my 800 I press the power button to display the current bike and by tapping on the bike name I can select one of my other bikes from the list.
Posted : 02/08/2013 12:51 pm
That should be put up in lights as THE typical STW reply i.e. ask a question about one thing you already own and get told to stop using it and get something else.
Posted : 02/08/2013 1:54 pm
This isn't a feature I've ever noticed on my 200...
Posted : 02/08/2013 2:01 pm
 st66
Lightman is simply suggesting that you can upload your ride to Strava from your Garmin and specify which bike you have used.
Posted : 02/08/2013 2:03 pm
Its not a feature I've seen on my 200 either.
Posted : 02/08/2013 2:05 pm
I just download the rides to Garmin Connect and put the bike used in the route name if it isn't obvious. Don't think the 200 recognises different bikes.
Then my mates tell me I should use Strava
Posted : 02/08/2013 2:09 pm
It's called a work around. Sometimes you cannot do exactly what you want, but there are ways to do nearly what you want and give you a similar result.
On my 500 I think I select it in the menu but to be honest it is not something I ever use. The strength in these devices is the downloading to software afterwards and studying it - as as mentioned above most software will have this for you. With some software, you can then break this down to miles on a particular bit of kit - say x miles on the tyres or chain etc.
Posted : 02/08/2013 2:13 pm
Cheers for your replies folks.
In comparing the 200 to others prior to purchase I must've got a tad confused.
So, what the point of the 2 odometers??
Posted : 03/08/2013 10:04 am
Ah, just googled the answer.
[url= https://forums.garmin.com/showthread.php?23556-Odometer-Readings ]Garmin[/url]
Posted : 03/08/2013 10:09 am
