Garmin Edge 200 dea...
[Closed] Garmin Edge 200 dead
[#5799849]
Worked fine on Christams Eve, quite a wet ride but nothing unusual, uploaded as normal.
Picked it up this morning - dead. Tried different chargers etc but nothing.
Anyone experienced this? Do Garmin or anyone else fix these units? Or is it a trip to Evans?
Posted : 26/12/2013 1:10 pm
Keep an eye out on amazon over the festive period. They had a flash sale on yesterday. Garmin edge 500 for 89.99.
Posted : 26/12/2013 1:33 pm
Ta, looking now.
Posted : 26/12/2013 1:38 pm
If you can't get it up and running I have an immaculate 800 with full uk topo maps which I would let go for a decent price.
Posted : 26/12/2013 1:41 pm
Thanks pik n mix, I think that it will be a bit too much computer and too much $$ for me.
Posted : 26/12/2013 1:45 pm
Mine is patchy with poor sat pickup so I called them to check it up.
Garmin will replace if out of warranty, from memory it was £56 for a new 200, so worth calling if you can wait until they are back in the office.
Posted : 26/12/2013 2:10 pm
tried the submerge and leave in rice trick in case some moisture got into it? worth a try. I posted the 500 deal a bit late, have just posted for Etrex 20 deal starting at 202pm but may well be others (a garmin a day?).
Posted : 26/12/2013 2:20 pm
My 305 would appear dead at times(usually after full charge) and they can go into sleep mode to prevent damage.. There was a combination of pressing and holding certain buttons to reboot(can't quite remember now) it's on garmin website or google resetting garmin 🙂
Worth a check before binning !!
Posted : 26/12/2013 2:25 pm
Try the Garmin Edge 200 forum.
[url= https://forums.garmin.com/forumdisplay.php?299-Edge-200 ]https://forums.garmin.com/forumdisplay.php?299-Edge-200[/url]
Posted : 26/12/2013 3:46 pm
Thank-you Dibbs, looking now.
Posted : 26/12/2013 5:41 pm
My edge 300 started switching itself off, particularly on bumpy roads. Turns out its a well known problem. The usb connector gets loose over time. I fixed it by putting a small piece of rubber behind the connector. There's lots of info on line.
Posted : 26/12/2013 5:49 pm
