Got a garmin edge 305, but don't use it as the mounts break repeatedly, cost about a tenner, and although the unit appears indestructible, I don't fancy seeing it go down a drain or under a truck.
Looking for something that does the same job, but doesn't fall apart. Heard another company might make something that works a little differently, but haven't yet found anything.
I've got those mounts on 4 mtbs and a road bike and never had a problem with any of them in 5 years - what do you do to them?
Never had a problem with mine to be honest, sometimes i cant get the bloody thing off though. 😀
How do they break?
I've got a 305 that's barely readable in light, the screen is so scratched and battered, but despite umpteen crashes I've never hurt either of the mounts.
They work in your jersey pocket too, you know, or the mesh pocket on a pack.
I also have been using a 705 with the same mount with no problems whatsoever. Got a mount on road bike and one on my Marin and they both get used every week.
I know, but you can't read them very well from there.
http://www.wiggle.co.uk/garmin-edge-bike-mount/
Go on customer reviews, then click on the filter, wears out easily.
Also here
http://www.chainreactioncycles.com/Reviews.aspx?ModelID=21502
Maybe it's due to you repeatedly 'slamming that stem' 😯
100% sympathise with OP
I lost my 305 on the Ridgeway due to the mount clip failing. The 705 replacement has nearly gone a couple of times and so I used elastic bands to hold in place.
The mount on the 800 is so much better, more positive hold and also reusable rom bike to bike via the band system.
I have not seen an aftermarket mount for the 305/705's which I think you are looking for
Just about to put an order in for this
http://www.amazon.co.uk/Garmin-Bike-Mount-Edge-705/dp/B000EGGRG6/ref=lh_ni_t
Apparently it's been beefed up a bit. Looks exactly the same..
That sucks David, and is exactly what I'm worried about. Don't bother with it off road, for exactly that reason. Just too risky.
Just to let everyone know, I am not ham fisted, I look after my kit, and I never crashed it. The mounts were just useless.
The newer mounts for the '05 series are better than the early ones. No where near as good as on the 500/800, but still and improvement.
If you still feel nervous, and you mount it on the stem, you can add a zip tie for security.
What's stupid is that they didn't put a little slot for a strap on the Edge. On the old Etrex's you could stick a wrist lanyard and use it as a safety strap (wrap round the bars and thread through) - I can't work out any way to do something similar on the Edge.
You could drill a hole in the outer casing I suppose. I've broken 2 of those mounts, but only when removing the gps. I'll happily admit to being hamfisted though.
I've had the same problem, had three mounts break on different bikes. Always just the tab breaking off, and the replacement mount kits are stupidly expensive when all you need is the bit of plastic that keeps breaking. I emailed Garmin to see if they were prepared to sell / goodwill some replacements of just the bit I needed but no joy, which I was unimpressed by.
Eventually I gave in and bought a set of 3 from an ebay seller in the US, for a half reasonable price.
just a little lol at losing your gps... yes i know you can't track the actual unit!
If only there was a way of attaching a lanyard using the slots in the SD card cover on the 705...
[url= http://farm7.static.flickr.com/6206/6057177616_eee5e92f13_b.jp g" target="_blank">http://farm7.static.flickr.com/6206/6057177616_eee5e92f13_b.jp g"/> [/img][/url]
[url=
[/url] by [url= http://www.flickr.com/people/druidh2000/ ]druidh_dubh[/url], on Flickr
I did manage to break a 305 bracket once, but the 705 version seems to be much stronger.
So how have you done that? can't work out from the pic (and can't find my edge, worryingly, to look)
Slide the SD card cover off and you'll see that it has two slots which allow the locking tab to move. A thin lanyard will slip into these slots. Just pop the cover back on and Robert is your parents male sibling.
I used my 305 for about 5 years on road, mtb and cx bikes. The bracket never broke on any ride - some of which included x2 24hr solo mtb races, x2 Tour of Flanders, the Marmotte, the 3 Peaks and about 20,000 miles of other riding. I must be doing something wrong.
The new bracket for the 800 appears reasonably robust although I'm not overly convinced by the rubber bands.
In seriousness I always hoped some honest person would find it, charge it then follow the last track back to my house. Some hope, they probably used it to smash a Tescos window.
+1, they're on my SS, the pitch, and the road bike for over a year with no issues, what do you people do to them!
