Garmin connect / ga...
[Closed] Garmin connect / garmin base camp
[#3701706]
Does anybody know how to get a route you've already done from your garmin dashboard to garmin base camp so that you can alter / extend your route for next time? I'm guessing you need to be able to save the route to a file somehow? and then import it to basecamp?
Cheers in advance for any advice.
Posted : 21/02/2012 9:50 pm
I don't use BaseCamp, but I import files to Garmin Training Centre and save them from there - not sure if that's any help!
Posted : 21/02/2012 9:52 pm
Select the activity and once it displays on it's own web page in connect there is an export button to the right of the edit button. Export as GPX and then import into Basecamp should do it.
Posted : 21/02/2012 10:29 pm
Sandwich.
Cheers that works a treat.
Is there any route planners that anyone can reccomend which you consider better than garmin base camp ?
Posted : 22/02/2012 11:41 am
Memory map. Much better than base camp but expensive.
The 3D route preview function is amazing.
Integrates with garmin computers seamlessly.
Posted : 22/02/2012 11:59 am
There is also bike route toaster for an online version. Google search should find it. I don't have the link to hand sorry.
Posted : 22/02/2012 12:13 pm
The new free garmin base camp comes with 3d option. Its a lot better now and easier to use.
You down load your route from garmin as gpx format to hard drive then upload to base map. Or attach your garmin and transfer directly from gps to software.
Posted : 22/02/2012 1:25 pm
I use Bike Hike, seems good.
Posted : 22/02/2012 1:29 pm
