Garmin - changing w...
[Closed] Garmin - changing wheel size post ride
[#5581325]
I did a ride yesterday on my road bike, but the Garmin was set up for my mountain bike i.e. different wheel size. I think it might have worked out the actual wheel size, but how can I be sure? Is there somewhere in the file that will say what wheel size the recording was based on?
Posted : 07/10/2013 8:39 pm
Isn't it using the GPS to measure distance?
Posted : 07/10/2013 8:43 pm
Is it a GPS one... if it is, then the satellites need re calibrating ...
[url= http://sheldonbrown.com/cyclecomputer-calibration.html ]God bless Sheldon Brown[/url]
Posted : 07/10/2013 8:44 pm
Which model, don't think you can change it after the fact anyway. It will only matter if you have a wheel speed sensor though ?
it's a Garmin 500, it has a wheel/ cadence sensor. Looking at the ride, the figures look similar to 2 others on the ride who recorded it on Strava so I think it's automatically recalibrated.
Posted : 07/10/2013 9:52 pm
I think the default setting for the Garmin speed/cadence sensor is auto calibrate, when this setting is used the Garmin automatically sets your wheel size after you've done a few hundred yards. If you've manually set a wheel size, more fool you. 😛
Posted : 07/10/2013 10:28 pm
