Garmin bar mount
[Closed] Garmin bar mount
[#6674329]
Any cheap alternatives to the 30quid official Garmin one! 1 for a 70mm stem and one for a 60mm stem! thanks lads
Posted : 01/12/2014 12:32 pm
+1 Sram
Posted : 01/12/2014 12:59 pm
+1 sram too
Posted : 01/12/2014 1:00 pm
 MSP
I have 4 bikes, the garmin original ones are just ridiculously expensive, the sram ones are still too much for a bit of molded plastic, just get a cheap one off ebay, they are exactly the same
http://www.ebay.co.uk/itm/J-L-Cycling-Computer-Mount-fit-Garmin-Edge-200-500-800-510-810-Bryton-Rider-MIO-/301175252626?pt=UK_SportGoods_CyclAcces_RL&var=&hash=item461f71a692
I was recommnded a Tate Labs Bar Fly on here before, and it's been spot-on (45mm stem here).
The bog standard garmin ones are cheap, 2 for about £6 the lay time I bought but have to be in the handlebars on such a short stem.
I've got the barfly one and it's good. though it mounts on the handlebar it still puts the garmin centrally over the stem.
Posted : 01/12/2014 1:07 pm
raceware 3d printed ones are nice, bit pricey direct but can often find them cheaper elsewhere (hint, search ebay).
Posted : 01/12/2014 1:12 pm
I bought one for my garmin 800 an out front mount and its perfect, its just a copy im guessing but cost me £9 delivered got it of amazon, sorry I don't have the link
just search amazon for garmin out front mount and im sure you will find it
Posted : 01/12/2014 3:24 pm
Is there something like the standard Garmin bar mount but more secure? That might screw on? I've got one of the SRAM ones above but I hate how far it sticks out and I can't reverse it because it doesn't fit over my stem at a reasonable angle.
Edit: Edge 200, 50mm stem & 5mm spacer.
Posted : 01/12/2014 3:28 pm
ska-49 - I think SRAM do a 'backwards' one that mounts in the same mode as the 'out-front' ones but puts the garmin over your stem. You can try doing that with a normal out front one backwards but IME the angles didn't work out well for viewing.
EDIT - just re-read your post and you've already said you've tried it back to front. I should learn to RTFP!
I have a couple of the SRAM branded out front mounts, which are very good indeed. I suspect the cheaper unbranded ebay/amazon ones are identical.
Posted : 01/12/2014 3:35 pm
K-edge do this for those of us running short stems:
[url= http://www.acecosportgroup.com/media/catalog/product/cache/1/image/500x360/5e06319eda06f020e43594a9c230972d/k/1/k13-550_family_wht_bckgrd_sm.jp g" target="_blank">http://www.acecosportgroup.com/media/catalog/product/cache/1/image/500x360/5e06319eda06f020e43594a9c230972d/k/1/k13-550_family_wht_bckgrd_sm.jp g"/> [/img][/url]
Posted : 01/12/2014 4:07 pm
Sorted lads thanks
Posted : 02/12/2014 9:20 am
I've also got SRAM mounts on all my bikes but does anyone know off hand if SRAM do a reverse mount that clamps on the right side of the bar as the one I have interferes with my Troutie light?
Posted : 02/12/2014 9:31 am
