Garmin 810 not char...
[Closed] Garmin 810 not charging
[#8381124]
Hi haven't used it for months - mainly as it was lost. I found it in the pocket of my cycling coat.
It has gone"flat" - which is a first... absolutely nothing ...
I have lost the cable it came with but have several similar ones .... however , no matter how I try and charge - so from laptop or mains, nothing happens, it remains blank.
Is it FUBARed ... or does it require a special magic white Garmin cable? If so, where does one get them from?
Thanks
Posted : 03/03/2017 9:48 am
Nothing special about Garmin cables. Sounds like it's gone into a deep discharge,but odd for that to happen in a relatively short space of time. Is it firing up at all when plugged into a PC?
Still under warranty? Worst case, Garmin support are very good out of warranty too (but expect to pay a flat rate to get it sorted)
Posted : 03/03/2017 9:52 am
Was cycling 'coat' in an outbuilding, ie very cold? If so, my Iphone used to do this, after warming up for a few hours, it would start to charge again, used to just put it on charge overnight.
Posted : 03/03/2017 9:56 am
Coat was in cupboard under the stairs
It has been left for months before and not discharged like this
When attached to the mains or a PC it does nothing ... completely blank
It like a very dead dead thing ...
And it is three years old ... so no warranty
Posted : 03/03/2017 10:13 am
My 800 used to have charging issues sometimes, it was usually down to a little bit of corrosion in the charging socket.
Try a bit of electrical contact cleaner in the charging port then try again. It worked with mine.
Posted : 03/03/2017 10:27 am
Pleas note, I have been misleading - it is a Garmin 500 not 810 ....
Posted : 03/03/2017 1:57 pm
Are you sure it is a 'charging' USB lead your trying it with -alot aren't and don't have the extra charging cable in them?
Does the lead your using charge other devices?
Posted : 03/03/2017 2:00 pm
Might just need a new battery. It's easy enough to do
Posted : 03/03/2017 2:01 pm
Try leaving it charging overnight - sometimes this wakes it up for some reason.
If that doesn't work, google 'garmin out of warranty' and open a support ticket with garmin UK. They'll replace the unit for a fee - can't remember how much but somewhere in the £50 region. Certainly cheaper than a new one.
Posted : 03/03/2017 2:04 pm
Garmin are going to replace it - 15 mins with tech support suggests it is fUBAR.
So they will replace for 68 quid ...
Posted : 03/03/2017 9:41 pm
