Garmin issues
[Closed] Garmin issues
[#6184293]
My Edge 705 seems to be chucking out spurious data. It seems to have started adding miles to my rides when I upload to Strava or the Garmin site. Is this likely to be a problem with the unit itself and if so, can I reset it? Would it make any difference?
Posted : 12/05/2014 11:57 am
if you look at it on a map what does the trace look like? Is it zig-zagging along the route with wild fluctuations.
Also, Strava will 'drag' any gps trace to the nearest segment if you ride close to one which can add distance.
Posted : 12/05/2014 12:01 pm
You might have it there. There are a lot of random zigzags, particularly on off road rides. I assume I'll be unable to fix this then.
Road rides are quite accurate.
Posted : 12/05/2014 12:37 pm
Are the "random" zig zags making the track line up with nearby roads at points?
Posted : 12/05/2014 12:43 pm
Checking for device updates if you've not done so for a while is worth doing too.
Posted : 12/05/2014 12:48 pm
Device is up to date!
@scotroutes....no. It seems to be worst where there is tree cover so I guess it keeps losing signal and then sort of making stuff up!
Posted : 12/05/2014 1:01 pm
GPS signals can easily be swamped by wet tree cover.
Posted : 12/05/2014 1:23 pm
I guess that might be it then
Posted : 12/05/2014 1:24 pm
