Anyone know if the Edge 1000 will fit onto the regular Garmin out front mount in terms of having enough room to rotate the device? I notice that there is now an "extended" out front mount which I am guessing is different to the original one? Or is it?
No it doesn't.
*blows raspberry*
Buggeh. Not cheap are they either. Thank goodness there's one in the box.
Cheers.
The one in the box is a horrid bit of plastic, k edge XL is nice 🙂
Hmmm, having had one of the tabs on the mount on my 810 break off when using a non-Garmin mount I am wary. It may not have been the mount, just bad luck, but would rather not have it happen again.
The fix was good though, Dogs Ear CNC replacement as recommended on here.
K-edge ones are known to damage the tabs because they're very tight, and have less 'give' being metal.
I thought the later K-edge mounts have plastic inserts to prevent tab breakage.
Aah, my apologies, you're quite right they do now. Problem solved!
Mate uses one of [url= http://www.ebay.co.uk/itm/400794388332 ]these [/url]for his Edge 1000. I have a couple of them, too (although I use them for an Edge 510). These place the device in line with the bars, rather than above.
