g2 forks ??
[Closed] g2 forks ??
[#2726341]
can the collective help thinking of buying a cheap 29er with the thought of putting rigid forks on and jones h bars and have seen a cheap gary fisher 29er ss but its got g2 forks on it if i change to a rigid fork thats not g2 will it make any diffrence 😕
Posted : 07/05/2011 10:44 am
Presume you're on about a 29er Marlin SS? Thats what i have as a winter hack. I used some exotic forks in the longer size, stuck some mud x on and a white industries freewheel and it's been fine through winter.
Posted : 07/05/2011 11:31 am
I had a G2 geometry Rig and put normal forks on it because that's all I had at the time. It felt a bit strange, but it was OK.
I bought some G2 forks and it was a lot better.
Posted : 07/05/2011 11:33 am
spot gfisher where did you get the forks from and how much trying to keep price down and was thinking of using on-one carbon 29er forks
Posted : 07/05/2011 11:40 am
£83 quid delivered direct from carbon cycles. I had the 46.5cm size as i was hoping the longer legs would help compensate for the 50mm G2 offset. I've ridden in Cannock Chase gloop all winter on and off piste and its been fine as a hack.
http://www.carboncycles.cc/index.php
Posted : 07/05/2011 11:48 am
G2 geometry has a shorter top tube, but a longer measurement between the steerer and fork sanctions... http://fisherbikes.com/bike/series/g2-hardtails
so the head angle will be the same but your wheelbase and top tube will be shorter
BTW, they also saved near enough 4 pounds in weight over the cheapo suntour suspension forks that came standard on the bike!
Posted : 07/05/2011 11:58 am
