I have an FSA MegaEvo 386 crankset. Trying to fit it to a standars 68mm shell on my road bike. When I fit it the drive side looks fine but the non drive side does not seem aligned. The arm is just a matter of mm from touching the frame when the cranks are turned and the wave washer is barely compressed.
Is there meant to be a spacer in the non driveside cup?? All the things I have read indicate no...
HELP!!!
Is that not an mtb chainset?In which case you'll need to use spacers.
No its a road chainset. Got it on my new road bike but decided to fit a proper BB30 one on that instead.
Now fitting this to my winter bike. Bought the cups and had this issue...
Is there a difference in the widths between road and mtb megaexo bb's?
Think there is between Shimano mtb and road
It's a MegaEVO though. It has a 30mm spindle compared to the normal 24. On the FSA website it says you don't need spacers.
I have put on a couple of the really thin plastic spacers you get with a sram BB and it seems tight and the clearence is a little better. Will see what it is like when I build the rest of the bike. Although I think heel clearence on the frame may be an issue.
Have you looked at the FSA website?
Here:- [url= http://www.fullspeedahead.com/techdoc/18/ROAD-CRANKSETS- ]http://www.fullspeedahead.com/techdoc/18/ROAD-CRANKSETS-[/url]
Yip, FSA website says no spacers and even watched a video of how to fit it. Seems I am doing everything correct but just seems odd with the clearence.
Have emailed FSA to ask as well, hopefully they reply.
