Full suspension fra...
[Closed] Full suspension frame help required - ideas please
[#11320873]
650b
None boost 142 * 12 rear
30.9 seat tube
Internal routing
130-160 travel
Less than £500
Large
Lls geo
What is there?
Posted : 02/08/2020 9:40 pm
Banshee Spitfire
(Part internal)
Posted : 02/08/2020 11:21 pm
Less than £500
Lls geo
I suspect that the first two exclude the latter point. Spitfire would work but I doubt you would get one for <£500. Can your existing wheels be adapted to boost? This may open your options (but getting latest LLS geo for £500 is still going to be pushing it imo).
Posted : 02/08/2020 11:56 pm
mk2 Rocket?
Not sure what they're going for now though. And not internal routing.
Posted : 03/08/2020 12:43 am
If it's a matter of building with the components you already have, then a 142mm hub is generally easily converted to Boost and a 30.9mm seatpost fits perfectly in a larger diameter frame with a good quality shim.
This is to say, don't shrink your options needlessly based on those 2 factors
Posted : 03/08/2020 12:46 am
You should look at the older Kona process 153. And go up a size.
Or a transition patrol and go up a size.
They are two brands that were ahead of the curve on shorter seat tubes.
Posted : 03/08/2020 1:03 am
You'll need a new seatpost, but you were being way too fussy anyway
Posted : 03/08/2020 1:04 am
Rear is a dt hub so can be boosted
Posted : 03/08/2020 9:21 am
Fails on the 30.9 and internal routing, but Bird Mk1 Aeris?
Posted : 03/08/2020 10:18 am
Older airdrop edit fits that?
Posted : 03/08/2020 5:36 pm
Bird would be perfect
Posted : 03/08/2020 6:50 pm
