Front mech with goo...
[Closed] Front mech with good tyre clearance for tight 29er?
[#9463986]
Yo, building up my 29er, got an XT M785 front mech, low mount 2 x 10, but the bulky swing mechanism fouls the tyre.
Had a look at some other mechs on mates bikes (9 speed triples) that definitely have much less bulk between the clamp and the tyre.
Anyone know which 2 x 10 spd mechs have less bulk so therefore more clearance? I'm guessing this has been a common problem on some 29ers!
Cheers guys
Posted : 28/07/2017 10:25 pm
The relevent Shimano Side-swing mech will do the job for you.
Posted : 28/07/2017 10:37 pm
I've got one of [url= http://http://www.chainreactioncycles.com/shimano-xt-m786-conventional-2x10-front-mech/rp-prod67203 ]these[/url] on my Solaris, as recommended by Cotic.
Posted : 28/07/2017 10:39 pm
Cheers guys, but aren't side swing front routed cables only? My frame is too routed cabling.
Chipster, linky no worky dude?
Ta
Posted : 29/07/2017 1:36 am
Sorry, op, what Zippy said ^.
It's dual pull, so top or bottom pull.
Posted : 29/07/2017 5:34 am
If you frame has a bottle cage mo7nt on the downturn then a couple of cable clips can be fitted there and will work well with a sideswing mech.
Posted : 29/07/2017 7:51 am
For reference/anyone else searching, I ended up with an X9, traditional band on. Gives more clearance as the bulk is offset to the outside of the seat tube. Think XX is similar if anyone cares 🙂
Posted : 14/11/2017 11:00 pm
I do, thanks. Got a similar issue with my Highball frame.
Posted : 14/11/2017 11:53 pm
Yes X9 is the answer, needed this with Turner 5spot HL.
Posted : 15/11/2017 12:22 am
Awesome, glad it helped. XO traditional style is a similar design too
Posted : 25/11/2017 11:08 am
