Front Mech - Top Pu...
[Closed] Front Mech - Top Pull v Dual Pull?
[#7244837]
I'm looking at the XT and XTR 11 speed front mechs for a 2x setup. Is there actually a different top pull only and dual pull version? Or is this simply just different descriptions for the same thing?
Posted : 04/08/2015 3:44 pm
Top pull generally only pulls from the top, DP lets it work both ways, they have a cable run that lets the bottom pull, pull from above
Posted : 04/08/2015 3:46 pm
That's what I'd assumed, just didn't know if it actually existed.
Posted : 04/08/2015 3:54 pm
check out the shimano tech docs, they do tell you everything
Posted : 04/08/2015 3:56 pm
Top pull = it will start rattling after about 2 years.
Bottom pull = it will never start rattling.
Posted : 04/08/2015 4:11 pm
There are dual pull and top pull only versions, the top pull only apparently gives you more clearance for running larger tyres.
Posted : 04/08/2015 4:23 pm
