Front mech height
[Closed] Front mech height
[#4639347]
Evening, replacing my x7 with an x9 front mech. However after looking at park tools site it says I should have about 2mm gap between the top of the tooth to the bottom of the outer cage plate. However mine sits much higher. Will I have issues shifting? The mech appeas to be the same setup as the x7. So is the height difference going to cause a major problem?
I was bought the x9 as a gift so not a necessary upgrade but got given so would be rude not too!
Posted : 10/12/2012 8:49 pm
Can you not lower it? I'd give it about 4mm. 2mm seems a bit close but we are splitting hairs here. Up to about 8mm should be fine.
Posted : 10/12/2012 8:54 pm
I have mine about 4mm high, mainly to allow the inner mech plate to clear the middle ring, any lower and it catches. (36t middle, 46t outer)
Posted : 10/12/2012 9:29 pm
No cant go any lower as it catches on the frame, it's a gr zaskar FS so the mech attaches to a little nub.
Running a 2x10 so no clearance issues on the middle ring.
Posted : 10/12/2012 9:36 pm
 Taff
2mm here, 3mm max. Never had shifting issues but never deviated from that approach in 15yrs of riding
Posted : 10/12/2012 9:46 pm
2mm park tools says is right (grammatically incorrect I know), issue is that mine is going to be greater than that.
Also should I have a med cage mech on a 2x10 setup?
Posted : 10/12/2012 10:00 pm
I've got an Xgen which seems to have a much higher mounting point than equivalent shimano mechs.
If I go for a 2mm gap as per recommendations then the outer plate catches the chainring teeth when shifting down. I have 4-5mm gap on mine.
Posted : 10/12/2012 10:40 pm
If your outer cage plate is 2mm higher than the top of your big ring how can it catch it when shifting down ?
Posted : 10/12/2012 11:15 pm
on a double set up its less crucial. suck it and see.
Posted : 10/12/2012 11:19 pm
Can't remember without having it in front of me. Seem to recall that the "downward" component of the mech swing catches the teeth before it has moved in enough.
Posted : 11/12/2012 12:11 am
