Trying and failing to correctly set up a direct mount 2x SRAM front mech. Any help tips greatly appreciated.
With the cable removed, set the inner limit screw with the chain on the largest rear sprocket, set the outer limit screw with the chain on the smallest rear sprocket, connect the cable and adjust the tension so that with the chain on the large chainring and the large sprocket, the mech doesn't foul the chain....
With the chain in any of the larger half of the sprockets, the chain will not shift from small chain ring to large......
Or, if I adjust the cable tension a little, with the chain in any of the smaller half of the sprockets, the chain overshifts the front ring
new cassette, chain, chain rings.
What could the problem be?
[url= http://www.parktool.com/blog/repair-help/front-derailleur-adjustment ]http://www.parktool.com/blog/repair-help/front-derailleur-adjustment[/url]
Work through this guide from the beginning first. Front mechs are a bit of a pain until you know what your'e doing. This is the best guide I've come across.
thanks devash - never had such an issue before, especially with full new drive train.
Will have a read before I swap the cable out and try again tonight.
Sounds like your high limit screw is still not wound in enough..
^ yeah, but if I wind it in enough, the chain wont change up when in any of the large sprockets
its almost like the pitch of the chainrings is a little to tight? is that even a thing
just a thought... although there is no rotational adjustment (vertical only) there is potential that the mech is bent - best check that
Is the cable/outer new ?
^ no, it will be in an hour tho!
