Front light recomme...
[Closed] Front light recommendations (Brompton, USB charging preferred)
[#5426336]
As above, what's the light du jour among the STW-Bromptonistas?
Want something nice and bright on the "be seen" rather than light up the roads sort of thing. Fit and forget on the bike when folded, and ideally USB charging.
Any suggestions?
(Not Knog, though. Have tried their stuff and always been disappointed!)
Posted : 15/08/2013 10:07 am
Been using a Lezyne micro-drive for a year on the front now. Bright, USB charges with no cables and easy to install/uninstall.
Had the back light that came with it, but the mount was a poor design so it got rattled out on a rough road - the front is a different design and much more secure.
Posted : 15/08/2013 10:10 am
 aP
The Electron Backupz USB charged LED lamps are good. Not great at the see, but good at the be seen.
Yes I don't think that knog make anything that lasts for more than a month or so, I file them with the Crank Brothers folder in my cabinet of stuff to buy/not to buy.
About 18 months ago I had a nice conversion heading along the Bayswater Road in towards NHG with a couple in a nicely restored Sunbeam Rapier who commented on how bright and visible they were. Then we talked about Sunbeams 🙂
Posted : 15/08/2013 10:17 am
Yep, much brighter than you'd expect for such a tiny light.
Posted : 15/08/2013 10:18 am
I have the leyzene too.
BTW the rear mount has now been improved. If you give upgrade a call they might even send you one
Posted : 15/08/2013 10:19 am
This one Captain. Charge up at work, gets me seen after dark on the chaos and violence of the A24 through Sarf Lahndahn...
http://www.cateye.com/uk/products/detail/HL-EL620RC/
Posted : 15/08/2013 10:25 am
Use 2 blackburn fleas ( 1 flashing, 1 constant) as my to be seen by lights. I've got both a usb, and battery charger for them,they seem to last around 6 hrs on low constant so charge twice a week in winter.
Posted : 15/08/2013 10:30 am
PS: on a Brompton, you may need to twist it on the bar before folding......
Posted : 15/08/2013 10:33 am
PPS: Where are you Bromptonning to and from these days?
Posted : 15/08/2013 10:36 am
I too use the Blackburn Fleas but I have a couple on the bars and one on my seatpost, though not fitted to a wobbly Brompton but a more sturdy Dahon Vitesse, and ride into tarn from Canary Wharf thro the CycleHighways and up Shoreditch/Old St/Clerkenwell/Holborn (hell) into Soho etc. so more than used to "Addison Lee Blindness".
HTH
Posted : 15/08/2013 10:37 am
For truely fit & forget you need to go for a hub dynamo.
I've got a Shimano on my front wheel and a Lumotec Lytn+ on the bars with the standard Brompton dynamo lamp on the rear. Both have capacitors in, so continue to blaze when stopped at junctions. Drag when on is barely noticeable
Bit more £'s than a USB light, but always there and nothing to charge.
Posted : 15/08/2013 10:42 am
Oh, we have the bottle dynamo on our work Brompton. Don't bother - the wires pull out of the bottle very easily when folding it.
Posted : 15/08/2013 11:06 am
TVM all, much food for thought, as per.
Am Bromptonning between That London's Famous City of Westminster and That London's Famous City of London at the moment. Along the etape du Embankment most days! 🙂
Posted : 15/08/2013 11:50 am
@greivoustim - thanks for the heads-up but a new bracket for the light will be useless - I didn't notice my light falling off until I got home.
Posted : 15/08/2013 12:01 pm
 lcj
The new Zecto lights from Lezyne look good and fit your requirements too?
Posted : 15/08/2013 12:09 pm
That Zecto looks gooooooood!
Given I have a Moon Shield on the back, that looks a pretty good match.
Posted : 15/08/2013 7:06 pm
