Front DT Swiss hub ...
[Closed] Front DT Swiss hub - QR to 15mm maxel conversion..?
[#4501189]
I have a set of Roval Control EL wheels, which have rebranded DT Swiss 240 hubs. I think these are what they call 'Standard' 240 hub as opposed to the 'Fifteen' and 'Oversize' 240 hubs.
I am using QR's and want to change to 15mm thru axle but Im having trouble finding the kit to do so. I have done some research but cant find a definitive answer on whether there is a kit to do the job. Because Roval is now part of Specalized now, there maybe the hard wear to do it in the US but isnt being sold in the UK.
I know the inner diameter of the bearings are 15mm so it could be done, and I dont mind swapping the bearings out if needed.
Any help would be much appreciated!
Posted : 27/10/2012 5:25 pm
I did the same conversion on a set of dt ex 1750 wheels, all you need are new end caps which CRC sell, have also seen them on a few German shops.
If your current hub end caps look like this:
http://www.chainreactioncycles.com/Models.aspx?ModelID=81483
Then you need the following kit:
http://www.chainreactioncycles.com/Models.aspx?ModelID=33708
All the best!
Posted : 27/10/2012 5:48 pm
Do you have the Standard hub or the Oversize hub?
My end caps look like this..
The the bigger cap goes on the rotor side.
Posted : 27/10/2012 6:10 pm
