Front derailleur ha...
[Closed] Front derailleur hanger fixing
[#7753012]
Is it possible to put a standard shimano deore triple ring attachment band on a mountain bike frame which has the newer welded on bracket for a double chain ring. I am thinking I may be able to use a file and grind down the welded attachment so the frame is almost circular and fit the deore band which can be moved up and down ?
any suggestions ?
thanks
Posted : 07/04/2016 10:22 am
Can you not just buy a direct mount mech, they are <£20 on CRC? You can get them in 2 and 3 ring versions.
Posted : 07/04/2016 12:09 pm
why would you want to do this?
Would the resulting tube even be a standard diameter for a band on mech?
Posted : 07/04/2016 12:11 pm
Already has a mech, would rather trash several hundred (?) quids worth of frame than buy a new one. (weird)
Almost certainly not, would have to get a new mech with an adjustable band (do they even make these anymore?)
Posted : 07/04/2016 12:25 pm
I think you are asking the wrong question, really we need to ascertain if the direct mount hanger is truly done for.
Pictures would be good.
Posted : 07/04/2016 12:36 pm
You should be able to get a triple mech for a braze on front mech. I wouldnt go hacking up a perfectly good frame if I could help it though.
Posted : 07/04/2016 12:37 pm
I think I've worked it out - you want to run a triple mech but the hanger is only setup for a double?
Before you go too much further I'd check the longer cage on a triple's not going to hit either the frame or a tyre.
And do you *really* need the extra range of a triple over a double?
Posted : 07/04/2016 12:38 pm
I am buying a frame with double mount and have a triple chainset to put on with a new triple derailleur. I wanted to know if there is any way I can easily do it with out buying new set up. Was not going to start hacking the frame, just wondered what the options were
Posted : 07/04/2016 1:27 pm
And yes the frame tubing diameter is the same.
Posted : 07/04/2016 1:29 pm
Realistically the options are to hack at the frame and potentially bodge it.
Or buy a new front mech and bash guard and go 2x.
Half an hour on a gear ratio calculation site will show you what gears you lose. As long as you are honest about your capabilities and speeds.
Posted : 07/04/2016 4:00 pm
Are you sure the existing mount won't handle a triple mech?
The "band" type come in a low version and a high version. One of these might fit under or over the direct mount plate.
Posted : 07/04/2016 7:11 pm
Assuming the frame design will permit one or other variant of the front mech other than a braze on type....
Posted : 08/04/2016 9:23 am
