can anyone tell me why I'm getting heavy juddering under front wheel braking..it's like abs judder..have a 29er with magura mt2 and xt hubs
I would check the following: Headset correctly adjusted. Callipers securely mounted. Rotors securely mounted. if all that is correct, then check the wheel bearings. Finally, ensure that the wheel is mounted and secured correctly. You can check for play in the headset by pushing the bike forward and applying the front brake. If there is still slight forward movement after the wheel has stopped, then the headset needs tightening. HTH.
I'm just going to get the bike in the kitchen and check everything..it's only done a couple of hundred mile so shouldn't be anything worn out
I once had magura brakes and the wave rotor that came with them caused terrible 'abs' feel judder. Swapped them out, judder instantly went.
alternatively your brake pads are contaminated with some oil
change them and clean the rotors
It could just be your pad and rotor combo juddering. On the other hand it could be fork bushings.
everything is tight just checked will get some brake cleaner on in morning....or I'll take it back again
Wavey rotor or worn disk Or oil/fingerprints. Defo not the pad.
I have the same issue but assumed it was down to the rotor and ignored it
ERM have you had the Allen key in to say its tight
Or just rocking it
Because it sure sounds like its a smidge loose
Had the Allen keys all round it..just decontaminated it and it's a lot better but not disappeared completely..I'll try another muddy ride then some new pads..it's a centre lock disc hub
