freehub woes - help...
[Closed] freehub woes - help me!
[#4767379]
Stumpy with some kind of dt swiss rear axle, but the freehub is completely kaput. Is it worth just swapping the freehub for a new one from crc etc, or am i best off replacing the whole hub and rebuilding?
I've searched the forum but can't find much help about freehub replacements.
Many thanks!
Posted : 18/01/2013 6:11 pm
 jonk
Which hub is it?
Posted : 18/01/2013 6:24 pm
 FOG
It will be a lot cheaper replacing the freehub and it's not usually a big job but you do need to know exactly what hub it is as if DT are like Shimano they have loads of different freehubs which are not necessarily compatible
Posted : 18/01/2013 6:35 pm
What's wrong with it ? A lot of Dt Swiss ones are serviceable
You can get the spring and two paws for the cheaper one which Spesh use a lot
The dtswiss web site has all the drawings and parts lists so you can see how it all works and which bits you can get
What year and model is your stumpy
Posted : 18/01/2013 6:46 pm
08 stumpy fsr expert, according to specialized [b]DT Swiss custom for Specialized 370 with DT RWS QR, 32h[/b]
Freehub keeps spinning round under pedalling, as if the ratchet is failing I suppose. It looks easy to remove the freehub, but I don;t know if it is compatible with generic shimano freehubs?
Posted : 18/01/2013 8:33 pm
If it is the same as my oem DT hubs from a Giant and a Fisher then you can pull the cassette carrier off and clean and regrease the assembly. Mine always start to play up in the cold too.
Posted : 18/01/2013 8:36 pm
If its like the other Dt hubs i have serviced,It needs 2 x Pawls that are £2.50 ea,A spring thats £2.50 and a Needle bearing kit thats £3.99 and maybe a few bearings if they feel rough.
Sounds like its just needs servicing.
Posted : 18/01/2013 8:38 pm
Cool thanks, I'll give it a clean and regrease and see what happens....bits all over the garage floor probably
Posted : 18/01/2013 8:41 pm
 kd48
Is it a 142+ 12mm hub ? I had one self-destruct on my Camber after 4 months. Unfortunately, one month beyond Specializeds 3 month free hub warranty. If it's one of these, only replaceable by the Specialized part which is a cheapo JoyTech free hub and you need a 14mm Allen key. Get a new rear wheel.
Posted : 18/01/2013 8:54 pm
I know a few people that have had hub bodies replaced well beyond 3 months by Spesh
Especial with the problems they have has this year.
Two of my riding pals have had wheel rebuilds with new hubs in the last 12 months under warranty
Posted : 18/01/2013 8:58 pm
hmm 3 and a bit years old now and bought second hand. WOrth a phone call to specialized just in case!
Posted : 18/01/2013 9:46 pm
Your dt one just needs a service , would not put that down to a warranty issue
Posted : 18/01/2013 9:50 pm
Spinning freely? >>> Service the pawls or replace freehub body
Wobbling all over the shop and/or/seized and less than 1 year >>>> warranty.
there is a more recent (non joytec) manufactured freehub as a replacment part for them which has been out a while, seems to be a million times better than the originals
Posted : 19/01/2013 12:09 am
Brickman do you know what the replacement freehub model is? Just in case it needs more than refurb
Posted : 19/01/2013 12:11 am
